Old 26th June 2010, 10:37 PM   #1
pjpoes is offline pjpoes  United States
Send a message via AIM to pjpoes
Default Biquad calculations for custom filter design
MiniDSP has now offered an "advanced" version of their crossover software that allows direct biquad coefficient filter design. I was a little disappointed to see that they didn't offer some method, in the program, to calculate these coefficients based on some given parameters.
I still want to use this ability for my room. I have one of these devices setup to be used in place of a Behringer DCX2496 for bass management/eq functions in my room. What I would really like the ability to do is take my measurements, target certain area's in the bass response, and create custom filters to target those problems. I know of some computer based filter software that can do that with FIR filters, but I don't want nor have the ability to run everything through a computer. I know that Matlab has Freqz as a method I can use to calculate the filter coefficients to put into the DSP device. Do any of you know other ways of accomplishing this?
I use Holmimpulse for measurements, and what I would love to be able to do is save out the results, input them into another piece of software, then be able to basically grab sections of the response, and have the software construct the filter from that.
As it stands what I can do is input a file from Holmimpulse into Matlab. Calculate the mean response level to use as my reference point. Then calculate deviations from the mean across the bass range of interest (I normally restrict this as 30hz to 100hz). Then basically hand pick the worst of them, and construct filters to match the inverse of those.
Can a biquad filter only be symmetrical? As it stands, I can only create symmetrical (about the center frequency) equalization filters to adjust for anomalies in the response, but my room deviations I'm correcting are typically not symmetrical. The only work around I can think of for this is to series cascade the filters in such a way to approximate the best correction filter I can come up with.
I have zilch for filter theory training and minimal knowledge, with even less DSP knowledge, so this is all pretty new to me. If any of my comments made zero sense in filter design, its probably because I have it wrong. My goal here is to construct more accurate room correction filters in the bass. I've looked into off the shelf options, but nothing can handle my needs and offer the flexibility I want. Those devices which can cost more than I can afford, or in this case, are beyond me to use.
Old 27th June 2010, 03:22 PM   #2
AllenB is online now AllenB  Australia
I can't offer assistance but I'd like to know the benefit of the bi-quad filter and how to select the transfer function. Subscribed for enlightenment Thanks.
Old 27th June 2010, 03:34 PM   #3
Biquad refers to biquadractic. It has no transfer function in and of itself. It refers to a 2nd order recursive filter, and is essentially the building blocks of digital IIR filters. You want a 4th order lowpass, just string two biquads together in series. The biquad has 2 poles and 2 zero's, by setting these through the coefficients, you get your transfer function of interest.
all digital IIR crossovers you've ever used has biquad filters creating those slopes as long as it's more than first order.
My interest isn't so much in their use to create high or low pass filters, I"m interested in creating notch filters and shelf filters. I will likely use these to create the crossovers for the subs as well, but at such low frequencies, the precise shape becomes a lot less important. In fact a lot of overlap becomes a good thing for my purposes, so I'm largely using 2nd and 3rd order filters.
The advantage as I see it, once I become a bit more savvy at creating these notch filters and such, is far more precise notch shapes which better match the room modes themselves. However, as I mentioned, the only way I know of to handle this right now is to cascade multiple filters together.
Old 27th June 2010, 03:40 PM   #4
...not meaning to hi-jack your thread, but does this mean filters and time delays combined?
Old 27th June 2010, 03:44 PM   #5
Time delay is a filter. It's an all pass filter.
Old 27th June 2010, 06:13 PM   #6
gedlee is offline gedlee  United States
Matt
I have a lot of experience doing this, but depending on the implimentation you could be up against a major problem. LF filters can be a real problem with Bi-quads. They are fine for higher frequencies, but round off problems and bit depth make LF a real problem. Can the board sample/resample to a much lower rate?
Bi-quads do not have to be symmetrical, but they are by definition always even orders. But then a first order augmentation is trivial, so an arbitrary order should always be possible.
Basically fnding the coefficiencts is never a big problem, but implimenting this in DSP on the board can be. The borad is fixed point DSP, right?
Old 27th June 2010, 08:10 PM   #7
Yeah I believe its fixed point at 56 bits. They refer to them as double precision 56 bit devices, I assume that is what they are referring to. I suspect that the ability to control the sampling is fixed even though I'm sure the board itself has hardware that can sample and resample at a variety of rates.
Well now you have me a bit confused. I thought from my reading that even devices like the behringer you like uses biquads in its programming to form the filters, it just calculates the filters to match analogue filters through biliniar transformation (I imagine this is actually predone and simply placed as a set of presets in the firmware). I assumed the first order filters were created through a direct form I method.
So are you suggesting that in most DSP devices the higher order filters, even the low frequency notch filters and shelving filters are achieved through another method other than Biquad's, such as through a direct form realization method? I have honestly only seen biquads in these more advanced dsp devices, so I just assumed that was how it was done.
I know the Behringer is a more usable device, my main reason for switching to the DSP device (besides the fact that I can tinker endlessly) was that I could cheaply cascade them to offer complete bass management in my room to best realize your suggested methods. I also felt that with fixed PEQ's I often would only get a best approximation of what I was looking for. I would move the center frequency a single hz at a time up or down, change the Q, etc. but often I found that when a big peak was followed by a suckout, non-symmetrical notch filters were needed. I know you don't love the excessive use of EQ, and I feel the same way, but I do think its a cheap and relatively simple way to get very good improvements in the bass response of a room, when used in conjunction of the multisub methods and working bass traps.
You have now seen the measurements of my room, its got a lot of issues. Many are not in the bass, but many are. I've got your two bandpass subs setup and one ULF sub in a corner. I have the Behringer in place with every PEQ it has being used, and you saw what I got. The bass response at each side seat is actually nearly flat, a little bit of eq went a long way. The middle seat, the "money seat" if you will, has a horrible response. The best I could even get was an average taken from 6 measurements within a box somewhat larger than my actual listening window, and is probably flatter than I hear. When you run the measurements you can just hear the differences in level as it goes up the decades.
Old 27th June 2010, 09:16 PM   #8
The issues arround the use of DSP filters at very low frequencies is not somethingbthat a manufacturer would want to tell you about. How Behringer does it I don;t know, but in general one has to have very high precision floating point calculation or very carefully designed filters to do LFs. It has to do with precision. A very small error at LFs equates to a very large discrepancy in the filters. This is not unlike the difficulty in getting good measurements at LFs with a finite length sample - its basically the same problem. The best solution would be to down sample to 2 Khz sample rate for the subs.
Old 27th June 2010, 09:30 PM   #9
JohnPM is offline JohnPM  United Kingdom
Caculating biquad coefficients for the various typical filter shapes is strightforward, a nice explanation can be found here. It is very unlikely that you will find the answers you seek by rolling your own biquads though, a single biquad has a rather limited scope and the asymmetries you see in the responses you are trying to correct are the result of multiple overlapping effects and need multiple overlapping filters to address them - if they are amenable to being addressed, which is by no means certain, and even less likely that a solution is possible for the multiple listening positions you appear to be aiming for. REW V5 has some filter tuning features that may help with filter settings, and can also show you the effects of your filter tweaks on frequency, impulse and waterfall responses as you make the adjustments, but the scope for addressing problems with EQ is fairly narrow.
Old 27th June 2010, 09:36 PM   #10
Originally Posted by gedlee View Post
How Behringer does it I don't know
The Behringer implementations (at least for DSP1124P, FBQ2496 and DCX2496) are all biquads at a fixed sampling rate. 56-bit precision from a fixed-point DSP (which would usually mean 24-bit data, 48 bit multipliers and a 56-bit accumulator to handle intermediate multiply-accumulate overflows) is sufficient down to at least 20Hz if implemented correctly.
Regarding Filter capacitr and DC choke calculations RAMESHKUMAR143 Solid State 0 8th February 2008 09:56 AM
Started to design solid state amp + calculations Bensen Solid State 11 22nd May 2005 03:55 AM
High/Low-Pass filter calculations Matttcattt Chip Amps 8 26th January 2005 06:38 PM
isobaric design. calculations anyone? keyser Subwoofers 4 27th November 2004 11:05 PM
Amp design calculations please? demons_wing Solid State 3 28th May 2004 02:26 AM
Page generated in 0.14407 seconds (72.89% PHP - 27.11% MySQL) with 10 queries
