I need an cheap project for the speakers that are 8 ohms and sensitivity of about 90dB or higher.
#2 |
Does anyone knew which tweater could replace adire he 10.1 orginal driver for tweater?
#3 |
Hi. Is this the same question?
PDF here: http://www.audioxpress.com/reviews/m...dell2119-1.pdf The PSD2002 is a very good driver. You can also test for Eminence Beta 10 CX & APT50. What about Eminence for home audio You have also the most recent development for the Burning Man Festival from diyAudio. ![]() Need good drivers for 'copper' speaker cabinet |
#4 |
Hmm...
Small speakers (bookshelf) + high efficiency means deep bass won't happen. A single full-ranger, perhaps?
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#5 |
Many say that he Adir 1.10 are quite good!
Does someone has or has had the opportunity to hear the adire? And maybe fostek driver in smal bookshelf cabinet? |
#6 |
Get a pair of bookshelf from Hsu speakers, rated more than 90dB, the negative side you may need a pair of sub.
| Budget bookshelf 2-way | cjkpkg | Multi-Way | 2 | 17th June 2010 11:51 AM |
| My last bookshelf. | R-Carpenter | Multi-Way | 35 | 28th May 2008 11:53 AM |
| bookshelf speakers - need help | ziv_r | Multi-Way | 1 | 24th April 2006 11:20 AM |
| The little exercise of bookshelf | fung | Multi-Way | 1 | 7th April 2006 08:35 AM |
| seas bookshelf | rv1890 | Multi-Way | 2 | 30th January 2006 10:24 AM |
| Page generated in 0.08621 seconds (76.79% PHP - 23.21% MySQL) with 10 queries |
