Old 25th June 2010, 06:08 PM   #1
Default Helmholtz Resonance (again)
Hi All,
I got a question about the correct calculation of a Helmholtz resonator. The formulars for a tube are:
fo=(c/2Pi)*sqrt(C/V)
C= (Pi*d*d)
4*(l+0.8*d)
where c-> speed of sound
d-> diameter of the resonator tube
l-> length of tube
V-> Volume of the box.
C is substituted
(I added a small Maple V R4 sheet)
The second formular can not be applied to rectangle-shaped openings.
Does anybody know how to adapt the calculation to a squared opening?
I searched the internet and my library, but I could not find that information.
Thanks for your help!
File Type: zip helmholtz_tube.zip (939 Bytes, 14 views)
Old 25th June 2010, 06:29 PM   #2
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
(pi*d^2)/4=pi*r^2
can you find formula for square\rectangle area? ..
factor of 0.8 is empirical and approximate.. use square side or slightly more instead of d
flesh flash flush
Old 25th June 2010, 06:46 PM   #3
@Flaesh
I hoped for a different factor than 0.8, one that represents the square in a better way. If I cannot find a better factor I will do what you proposed.
Old 25th June 2010, 06:58 PM   #4
Flaesh's Avatar
and if port is wide and short, or near box side\floor, or rounded - this 0.8 seems greatly approximate..
flesh flash flush
Old 25th June 2010, 08:42 PM   #5
mjf is offline mjf  Austria
hello.
i think both channels (round or square) should have the same volume.
if you use the same length you only have to calculate the the area to get the same volume.
transl:bei gleicher länge des kanales einfach die querschnittfläche so anpassen, dass sich wieder dasselbe volumen ergibt.
grüsse
Old 26th June 2010, 02:00 AM   #6
Inductor's Avatar
Correction factors from round to square (a/b):
0,988 for a/b=square
0,9 for a/b=3,5
0,8 for a/b=7
http://pagesperso-orange.fr/francis....ank_Pierce.gif
More here: Huesbscher
Bass-reflex : Calcul de l'évent'
Old 26th June 2010, 04:31 AM   #7
Thank you for your help!
Resonance vs Time MaVo Multi-Way 2 8th January 2008 11:11 PM
Cabinet brace act as helmholtz resonator? RyanW Multi-Way 17 2nd October 2007 11:08 PM
Helmholtz bass absorber, where to place? banana Multi-Way 3 26th July 2006 04:13 PM
Dont want mr. Helmholtz in my sealed sub ! Coolin Subwoofers 18 14th October 2005 09:13 PM
Any experience in designing a Helmholtz bass trap? MarceloSQ Everything Else 4 5th July 2002 07:33 AM
Page generated in 0.10132 seconds (63.97% PHP - 36.03% MySQL) with 11 queries
