I'm going to buy these speakers (unless you can suggest better in the UK for the same price
Thanks a lot. Boscoe |
#2 |
that combination does not look like playing music together. But things can be surprising. If you do not want to change to a tweeter able to cross at say 2-2.3 Khz i would do the following: Build an appropriate box for the woofer, ensure that the damping behind the driver (sheep wool e.g.) is able to suppress coloration in the midrange to presence region. Try to make a minimalistic filter , which utilizes the natural rolloff of the driver: That could be compensation of voice coil inductance only, or additionally using a very small INDUCTOR in series. It could also be nothing. Try to get the sound of the woofer as "correct" as you can without the tweeter, make some measurements if possible, listen to speech and music without the tweeter. The combination has to be optimized for a certain listening distance, because the directivity of the woofer is narrowing with frequency. Do your listening tests at that prefered distance (should not be too far away) Play with listening angle, result may be better slightly off axis. This will be a speaker which has to be positioned due to a sweet spot according distance and angle. Then add the tweeter and experiment with filters from 2. order. Look what happens, if you use textbook values and try making the parallel coil "too big" or the series capacitor "too small". Decide whether the tweeter has to be padded down using an L-Pad. Recessing the tweeter to the plane of the dustcap of the woofer may be good, keep the tweeters plane movable while tuning the filter (Put it ontop of the cabinet, near the woofer). Play with the distance offset and the polarity (should be in antiphase normally). If you can't do measurements listen to white noise from a tuner and signals like applause while tuning the tweeters position and filter. Keep the crossover frequency out of the presence region, rather move it as high as the woofer allows. No risc no fun ... Last edited by LineArray; 23rd June 2010 at 09:56 PM. Reason: deleted "capacitor" added "inductor" |
#3 |
Did it Himself
It's a ribbon tweeter with resonance at 4500Hz, there is no way it can be used below 5000Hz. The 8 inch driver you have chosen will not really stretch up that well to 5000Hz, you may get away with THIS tweeter.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
Nice one thanks for your time.
I will just have to change the tweeter i think, it just seems the easiest option. What do we think of the quality of theese drivers? |
#5 |
Did it Himself
They are reasonable, perfectly fine for a first design. In fact better than what I used in my early designs!
#6 |
Here's a thought - a wide-band mid-high driver. Perhaps a 2-3" driver, with decent efficiency. Cross it over where you like, but you'll need a small enclosure to stop it being pushed around by the woofer.
Just to throw another idea out there...
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#7 | |
#8 |
How about the Stage Line DT-300 103860. It has an fs of 750Hz, 93db and 50watts RMS.
#9 |
This 2" TB fullrange tweeter is quite good, and cheap
its actually more like 1.5" resolves exstremly well at moderate spl acoustic instruments like violin, piano etc. are just spot on almost as good as it gets and you can cross it low I have a very special but simple xo for it, if you are interested all you need to do is adjust woofer xo to match it probably just a series inductor with a zobel crossing relatively low makes it easier to do the BSC thing |
| Bias worry | bigwill | Tubes / Valves | 5 | 18th April 2010 07:55 AM |
| Buying worry | Dr.EM | Everything Else | 2 | 8th October 2007 01:40 PM |
| Fequency cut-off for Direct coupling GC | 100db | Chip Amps | 7 | 7th October 2006 03:39 PM |
| SPL's vs. Low fequency | MazzPotential | Multi-Way | 8 | 6th July 2002 11:21 AM |
| Page generated in 0.11581 seconds (71.51% PHP - 28.49% MySQL) with 11 queries |
