Old 23rd June 2010, 05:30 PM   #1
Default Replacement woofer for JBL LM38
Hi everyone,
Long time lurker...first time post.
I'm replacing the 8" woofers in my 3-way JBL LM38 speakers. The enclosure is ported with a 1.5" diameter tube and the interior volume is 1 cu. ft.
I would like to know whether the Hi-Vi M8a woofer (see attached .pdf) ia a good replacement given the enclosure size and musical detail or would a Hi-Vi M8N or Hi-Vi D8G be better. I listen to all types of music but my goal is to be able to listen to classical music (kettle drum and upright bass - double bass) and have a clear, tight, and detailed reproduction.
I will be replacing the 6" mids and 1" tweeters and crossover soon but I thought I'd start with the woofers first.
Thanks.
Old 2nd July 2010, 04:55 PM   #2
WOW... I feel like a major dope!! I don't have JBL LM38's!!!
I have these:
JBL MR38
45Hz-20kHz
92dB sensitivity
150 watts
3-way
14mm Titanium tweeter
6.5" mid woofer
8" bass woofer
Sorry for the mis-information, I was going from memory and memory isn't what it used to be. So as I mentioned before I want to replace the WMT speakers with something more balanced and detailed.
So, I did some research and purchased a pair of HiVi M8a speakers. Swans recommends a 28 liter vented enclosure which matches the volume of the MR38. I think I can tune to the F3 without any issue.
One thing I noticed about the M8a is the high impedance at 33Hz (65 ohm)
I was wondering if I should build a Zobel Circuit for the speaker and if so how can I determine the Le? (The speaker is 8 ohm)
I'm still looking at mid's and tweeters...so does anyone have suggestions that would make building a XO pretty straightforward?
My amp is a SS Sony DTR511 which is about 40W per channel. Nothing fancy but something that serves its purpose.
Thanks in advance.
Replacement driver for JBL LX44 arbourm Multi-Way 0 18th December 2009 12:38 PM
Discrete amp based on LM38-- family internals? tiltedhalo Solid State 1 16th November 2005 01:06 AM
Replacement drivers for JBL N26II DcibeL Multi-Way 16 2nd March 2005 09:51 PM
JBL 5in woofer Praudio Swap Meet 0 8th May 2004 09:35 PM
Page generated in 0.07632 seconds (64.59% PHP - 35.41% MySQL) with 11 queries
