Midrange - cones vs Compression drivers?
Old 26th June 2010, 12:15 AM   #21
angeloitacare is offline angeloitacare  Brazil
angeloitacare's Avatar
hi Peter
the midbass horn is 75cm long, and the adapter another 15cm. So total 90cm. I lowpass at 1khz, 6db. I think about make later on a adapter, to use the back of the diaphragm without phase plug straight annexed to the horn, without the 2" to 4" adapter, and close the backchamber , with foam, same as the Fane Studio 8m. So the backchamber will be bigger than it is now, and aloud the driver to go lower. The backwave will radiate into the phaseplug, and back into the bigger backchamber. That will lower Fs of the driver. Maibe this weekend i will make some measurements.
Old 26th June 2010, 12:37 AM   #22
limono is offline limono  United States
I also experimented with idea of compression driver upperbass. Electrovoice used it in their Patrician IV horns. On the picture is oversized mouth 100Hz taper dual compression driver reentry units in compound configuration.Yes it ads a lot of snap, energy and dimmension to the sound but ultimatively I gave up because after a while one notice that the body and low end response is lacking and the sound is to dry. The horn was crossed 200Hz-600hz. I'd suggest cone driver and with time compression driver from 400 up. in suitable horn.
Old 26th June 2010, 09:36 AM   #23
pk is offline pk  Denmark
Originally Posted by angeloitacare View Post
hi Peter
Hi Angelo,
Thanks for responding!
Best regards
Peter
Old 26th June 2010, 10:40 AM   #24
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
.. the backchamber will be bigger than it is now, and aloud the driver to go lower. The backwave will radiate into the phaseplug, and back into the bigger backchamber. That will lower Fs of the driver..
are you sure - diaphragm will not meet with phaseplug?
.. Maibe this weekend i will make some measurements.
very interesting..
flesh flash flush
Old 29th July 2010, 07:14 AM   #25
jlwitherell is offline jlwitherell
Originally Posted by Robh3606 View Post
What do you consider midrange?? Where do you want to crossover?? I have a couple of horn/waveguide systems. I really like the JBL 10's like the 2122 or 2123. They run from about 250-300 up too about 1.5K in the two systems I use them in. They sound great the only issue can be the 1.5K crossover point in you want to stay away from there with a crossover.
My other system uses a 3" compression driver crossed over at about 750hz and then at 8K to a UHF driver. Another really nice sounding system but with the woofer covering the lower midrange.
You have to name your poison as far as where you want the crossover points to be. As long as the crossovers are well implimented either way will work.
Rob
Hey Rob, I have a pair of 2120 professional series 10's, d130 15's and bullet tweeters. years ago in high school I made a box which held them all. Behind the 10's in made a virtually no airspace box inside the larger box. the entire system to me then sounded fantastic. Have you ever put the 10's in virtually no air space? I'm thinking about building another box and am trying to find the best way to use the 10's as mids (as well as save space if possible). I can't seem to find anyone recommending this on the web but at the time I swore someone in the industry told me that jbl would recommend no air if using these 10's as mids... Thanks in advance for your advice and/or thoughts.
-josh
Old 17th September 2012, 09:44 AM   #26
YaoSiTing is offline YaoSiTing  Viet Nam
Hi Rob and Josh,
I have 1 pair of JBL 2120 Pro and Celestion's bullet tweeters like Josh's too, I want to make a new cabinet for them. Please could you instruct me with details of cabinet/design picture?
Forward from you.
Old 13th September 2015, 11:13 AM   #27
Scott L is offline Scott L  United States
Default resurrection !!
The resurrection of a thread !
I found this quite interesting and there were a few unanswered questions posted here about 5 years ago. Assuming most here are life long tinkerers,
I would welcome a few progress reports. Myself, like the Bear, try to avoid a crossover in the 250-3.5kHz range, but that's not always possible.
Old 13th September 2015, 09:41 PM   #28
Last week i connected my lower midrange horn with Fane Studio 8M. Did not change the settings of the crossover. It sounded aweful to me, compared to the Beyma 12p80nd. Colored and unpleasant. Switched soon back to the actual configuration.
Old 14th September 2015, 08:43 AM   #29
Hello Angelo,
Yes, your set up with Beyma 12p80nd/ TPL-150 combination is somewhat legendary now !
How much time has expired since you first tried this?
2 years ?
3 years ?
Old 15th September 2015, 02:49 AM   #30
Originally Posted by Scott L View Post
Hello Angelo,
2 years ?
3 years ?
hi Scott
i am not changing my configuration for at least 3 years....
how about u ?
Midrange - cones vs Compression drivers?Hide this!Advertise here!
Compression drivers or cone drivers - what do you prefer? Defo Multi-Way 25 28th February 2010 10:57 PM
Compression ratio and diaphragm size in compression drivers inkasound Multi-Way 50 8th January 2009 03:38 PM
Looking for a 1" bolt on compression midrange Cal Weldon Multi-Way 8 13th October 2008 06:47 AM
21" Bass Drivers and Beyma Compression Drivers Magnetar Swap Meet 0 19th November 2006 02:42 AM
