Old 21st June 2010, 04:55 PM   #1
Hylle is offline Hylle  Denmark
Default debt and hight perspective
in speaker performance, what have influence on the hight and debt perspective? I fell I have difficultees to reach the performance in my DIY speakers as on the best speakers I have heard.
Also i feel it has something to do with how the speakers project its sound out to the listener, it is good to avoide reflections on the walls, seeling and floor.
Old 21st June 2010, 09:32 PM   #2
ScottG is offline ScottG  United States
Well the hight, or high-t is short for "high tariff".. or the "hosing" you Europeans get on imported goods.
The debt perspective is inevitably the perspective that results from paying for goods with a "dizzying" hight.
The subjective responses of Height, and Depth are very complex (and not well understood).
For the most part Height can be enhanced by moving the tweeter/mids physically higher in relation to you - aimed at you. (..Wilson Audio does this for their larger designs, like the Alexandria and MAXX.) You can also usually enhance Height (and Depth) in a normal stand-mounted type design by moving the tweeter off of the front baffle and onto the top of the loudspeaker and tilted "up" about 20+ degrees (..though be wary of diffraction effects and on and off axis responses.)
Depth is largely due to the quality of the drivers, and the passive components (i.e. capacitors and inductors). You can also increase it by lowering the midrange spl level when compared to the average (particularly between 1 and 4 kHz). Further, delayed ceiling reflections can enhance the sense of depth (contributing to a monophonic emphasis).
It generally is NOT good to avoid wall and ceiling reflections as long as the speaker is a meter(+) away from any wall. It generally *is* good to reduce floor reflections, though the Alison effect (or midrange loss in pressure due to "floor bounce"), can sometimes improve depth.
perspective is everything
Old 22nd June 2010, 08:24 AM   #3
StigErik's Avatar
Height perspective is really not possible with two speakers separated only in the lateral plane, but some people do "hear" height perspective anyway, and some do not, including myself.
As ScottG points out, there are a lot of things that affect our impression of depth and spaciousness, but the most important factors in my opinion is the quality of the speakers, the quality of your room, and how the speakers integrate with the room.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 22nd June 2010, 05:59 PM   #4
Thank you for the good points. maybe I am one of those that does not hear hight perspective.
I often have a feeling to hear bette depth perspective, if loudspeakers are fare away from the back wall.
But i guess as you indicate, that these informations are in the lowlevel small signals so very high quality on the design is needed.
The best designs I have hear these detail on is a line source and a 3 way with very simpel crossover, only a capacitor on the tweeter, the midrange was a fullrangedriver, and the bas was made in a way so that it had a natural roll off that fittet to the fullrange driver.
Old 22nd June 2010, 10:17 PM   #5
If you liked the sound of those 3ways with just one capacitor you could do worse than looking at active designs.
I think what you liked might be the effect of having the amp directly driving the speakers rather than through a more or less complex passive crossover.
Old 23rd June 2010, 06:34 AM   #6
Yes, you might be right Charles, but then again the line source had a traditional crossover, with high quality parts.
hight idle current HARMAN amplifier ericb Solid State 0 2nd March 2008 04:09 AM
OPAMP for hight V_swing ? foo Parts 2 17th June 2006 07:07 PM
Arm Board hight demensions fortytwo Analogue Source 2 26th October 2004 07:47 PM
Problem With Hight Power Solid State Amplifier vytas Solid State 0 2nd September 2004 02:54 PM
debt!! mikee12345 The Lounge 0 4th April 2003 06:37 AM
Page generated in 0.12211 seconds (60.15% PHP - 39.85% MySQL) with 10 queries
