9h)This is for a music studio... room is 14'(w) x 20' (l) x 9' (h) . The idea is to have a very, loud, distortion free, full frequency speaker. All critical decisions during recording and mixing will be made on well proven near field monitors. These will serve to impress clients and as an alternate monitor to see how stuff sounds when really loud. I am not going for the ultimate level of finesse or detail here... just a robust, practical monitor that can, at the very least confidently make the high 20s in terms of low frequency extension.
I am considering building this because any commercial system of this size and power and this level of flexibility and speaker-to-room tuning ability will cost at least 5x what this build might cost me. We are poor I am looking for opinions on my current selections, and how I can improve on it, given the price point. I chose the mid-bass and tweeter units based primarily on their power handling capabilities. As I understand, both the units can withstand up to 1000 watts. Unmixed music can have totally unpredictable levels. Such things are tamed over the mix process... therefore the speakers must be strong enough to take the punishment. At this time, I'm thinking: 1 x Subwoofer per side powered by Peavey IPR 3000 1 x Morel CAW 638 6" Cast Frame Woofer per side - powered by Peavey IPR 3000 - crossed over @ around 3 KHz to 1 x Morel ET448 Elite Tweeter per side - powered by a Peavey IPR 1600 Currently, these will be managed by a Behringer DCX2496... hoefully to be upgraded to DEQX. Apart from any general feedback, I want help in picking my subwoofer drivers. I'm looking at The Dayton Titanic Mk-3 primarily because its relatively affordable and has good specs as far as I can tell. Also the Peavey IPR3000, which is probably the best spec'd amp at its price, should be able to power it. The Maelstrom-X looks very good, but its seriously pushing my budget. Will the Peavey IPR3000 be sufficient to power it? Similar concerns with the Soundsplinter RL-P15... would anyone recommend this model over the Dayton Titanic, for my use? Are there any others in the range of $300? Thanks, |
#2 |
Checkout the Peerless subwoofers which are very popular and well-priced.
Subwoofer | Tymphany I'm using the Seas L26ROY which is very fast, important if music is your main media https://www.madisound.com/store/prod...oducts_id=8535 Also, I think there are better midwoofers around than the Morels. Check out those by Peerless, Vifa and Seas |
#3 |
If power& budget are the directives , why not going to another path ?
Instead of such tweeter ,why don't you find a good compression driver ? Efficiency pays and you won't need another amp or electronic Xo . Such raise in sensibility would be matched by adding a pair of mid-wf ,as in a MTM configuration . On the other side ..Building in-wall also would help in finding a good compromise for the bass , horn style ,so maybe a good bass performer with an attitude to midrange and a hungry tweeter would make the "thing" going(2*Pi radiation phase coherent patent tm |
#4 | ||||
Can you suggest a particular model? Thanks, Last edited by audiothings; 20th June 2010 at 06:13 PM. |
#5 |
From The voice of the theater to that compact self-amplified speakers you said you listened to. Why not a pair of 8" on a tall enclosure ,something like a Curvy Chang (for the proportions , see on the FR forum ) with a mid and a tw ?
| Welcome to see my DIY Wall Horn | FYC | Multi-Way | 4 | 25th September 2007 04:42 PM |
| diy wall shelf | francisco.josè | Analogue Source | 0 | 6th January 2007 10:06 AM |
| DIY In-Wall TangBand 871's? | CrisTUFR | Multi-Way | 4 | 14th May 2004 07:37 PM |
| DIY wall-mounted speakers | Donut | Multi-Way | 4 | 16th September 2002 06:10 AM |
| in-wall DIY for HomeTheater room... | hakalugi | Multi-Way | 1 | 17th January 2002 11:32 PM |
| Page generated in 0.11627 seconds (68.86% PHP - 31.14% MySQL) with 10 queries |
