Old 18th June 2010, 03:31 PM   #1
Default Voigt pipe as a TQWT
Forgive me for not finding this by searching as I'm sure it must have been considered at some time....
What's the advantage of the stuffed triangular peak of a Voigt pipe? What do you lose by cutting it off and just having a more typical TQWT?
Old 18th June 2010, 06:49 PM   #2
frugal-phile(tm)
planet10's Avatar
I usually use Voigt & TQWT interchangably.
You question then becomes what is the difference between S0 = 0 vrs S0>0
Depends on the line, and the driver. When i was consulting with Scott on Demetri & Mileva, line length was extended (with the same taper) such taht S0 became 0 with no appreciable effect (except making the box easier to build)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th June 2010, 04:18 AM   #3
You're a mind-reader, Dave!
Yep, my next question is, what is the difference between S0 = 0 and S0>0 ?
Old 20th June 2010, 04:28 AM   #4
frugal-phile(tm)
planet10's Avatar
Scott or Greg?
dave
Old 20th June 2010, 06:53 AM   #5
GM is offline GM  United States
GM's Avatar
SO = 0 = infinite (Dc) band-width (BW) throat in theory, but it has a tiny incompressible air boundary area in reality, so the effective throat area frequency is way up above our hearing limit, ergo any larger area progressively lowers the pipe's throat frequency with increasing area, i.e. its high frequency limit.
Ideally then, a pipe horn such as a BIB or Voigt pipe would be designed using horn theory, but few, if any have been. As already noted though, increasing stuffing at the peak of a SO = 0 pipe acts as an acoustically larger throat plus typically yields superior damping to a damped larger throat area and easier to build if folded, so is what I prefer.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st June 2010, 10:17 AM   #6
Oh, duh! Never mind.....
I forgot they flared in different directions.
Goodmans Axiom 201 in TQWT Voigt Quarter Wave Pipe? calvert73 Full Range 60 3rd January 2012 09:32 PM
Voigt Pipe is looking for new home mkapszewicz Full Range 9 21st December 2009 02:17 PM
w15cy in a voigt pipe sergiof Multi-Way 16 28th August 2009 11:58 PM
Folded Voigt Pipe Ropie Full Range 18 2nd November 2005 03:31 PM
MTM on a Voigt Pipe ? johninCR Full Range 2 8th April 2005 06:20 AM
Page generated in 0.09595 seconds (64.88% PHP - 35.12% MySQL) with 10 queries
