Hey Gang.....i Ordered a Bunch of Buyout Speakers from PE for a Future Planned.
i Have 4 Bravox Blue Poly Cone 6-1/2" Woofers 2 Bravox Poly Cone 6-1/2" Subwoofers (or Should i say...woofers) 2 Nuance 10" Woofers 5 JVC 3x5" Full Ranges 3 Atlantic Tech. Mylar Dome (Really a Cone) Tweets. (The Fourth One i already had) the Blue Cone Woofers will be in a Bookshelf Speaker,likely an MTM...each one with a Mylar Tweet. the JVC Fullrangers will be used for a Small 5.1 System...the Two Fronts will have a Mylar Tweet...for a little more Crisp...though they do extend high enough without it....the little Sub...or Bass Module i should say will have the Two Bravox Subwoofers in it...which should be pretty sufficent for a small room. the Nuance Woofers will be used in a Passive Subwoofer....while they aren't listed as Subwoofers they seem to have sufficent Xmax for a Sub...especially with two. any Suggestions,thoughts or ideas?...i think its a Pretty Cool Idea. |
#2 |
Banned
Nuance 10" Woofers, = junk! their manufactured retail speakers were crap too. PURE CRAP!
The blue ones look sexy, do you have any more information on them ? Do you have a tweeter in mind ? Your best bet would be to match them to a good tweeter, sensitivity wise that is.! |
#3 | |
dunno about their Retail Speakers....but those 10" Woofers are Quite Decent...the Magnet seems just a Tad Small,but they make Nice Bass and have a Little bit of Excursion. The Blue Ones can be Found at the Following Link. Bravox WFR-06BV02S 6.5" Poly Cone Shielded Woofer 12 Ohm | Dahlquist WFR-06BV02S 6-1/2" Poly Cone Driver 12 Ohm Woofer bass mid midbass mtm full range line array midrange surround sound center channel bravox shielded monitor 2-way Dahlquist162010 Woo the Tweeters im using are in the Pictures with the JVC 3"x 5" Drivers. they are Mylar Tweeters....they do Give Sizzle...ill put it to you that way...i might have to Pad them down just a little....they will overpower the woofers abit. |
#4 | |
Banned
Blue's look good. But the 10" are garbage. Not worth, wasting your time on |
#5 | |
the Blue and Black Bravox Woofers are Pretty Similar to Each Other..they both have Pretty Much the same Size Magnet...and both have venting behind the dustcap rather than a Pole Piece....they are pretty Quiet at Large Excursions..i should have gotten More of the Blue's....those are some Sexy Woofers,lol Nuance 10"?....Still Not JUNK! ![]()
#6 |
Ok maybe they do Suck a little.....i ran them at High Excursion...and the Leads Slapped together Real Bad.....Ack
| which Mark Audio driver for future project, And WHY? | mondogenerator | Multi-Way | 15 | 14th January 2010 05:57 AM |
| Proac Future 2 project parts plus more for sale. | Merlin | Swap Meet | 4 | 6th March 2009 04:59 PM |
| Very near future project, need input... | chops | Multi-Way | 36 | 16th August 2007 12:20 AM |
| Need help - O/T trannies for future project | Simpleton | Tubes / Valves | 13 | 31st August 2005 03:39 PM |
| Unfinished Proac Future 2 project F/S | Merlin | Swap Meet | 0 | 1st May 2004 12:06 PM |
| Page generated in 0.11381 seconds (68.36% PHP - 31.64% MySQL) with 11 queries |
