To choose the right driver for a bandpass box, I wanted to know the effect of driver parameters on the box. This way I could adjust the size and cutoff frequencies by finding the right driver.
Four parameters are needed for a design. Three driver parameters: fs, Qts and Vas. You choose Flow to suit your needs. This table shows the effect of increasing these four parameters by showing what happens to the box when you do. Code:
| Increasing| Increasing| Increasing| Increasing
| F low | Qts | Fs | Vas
_____________|___________|___________|___________|________
F high cutoff| Increases | Decreases | Increases | No effect
Rear volume | Decreases | Increases | Increases | Increases
Rear Qtc | Increases | Increases | Decreases | No effect
Front volume | No effect | Increases | No effect | Increases
Front Ftuning| Increases | Decreases | Increases | No effect
Gain | Increases | Increases | Decreases | No effect
1) To decrease the front box volume, choose a lower Qts or a lower Vas. (no other parameters make a difference) 2) To decrease the rear box volume, choose a lower Qts, a lower Vas, a lower Fs, or a higher Flow. 3) To lower the Fhigh cutoff, choose a higher Qts, a lower Fs, or a lower Flow 4) To increase the gain, choose a higher Qts, a lower Fs, or a higher Flow. Changing some of these may have a side effect, for example: If you want to reduce the Fhigh cutoff but you don't want the box size to increase, the only way to do this is with a lower driver fs. A tip when comparing two drivers to see which will give you a smaller box, two parameters: Vas and Qts, have an effect on both the front and rear box sizes. Vas has a direct effect, i.e: halving Vas halves both parts of the box. Halving Qts will halve the rear box, but will quarter the size of the front box, therefore, Qts is slightly more useful in reducing box size, and Qts will also reduce gain. Last edited by AllenB; 12th June 2010 at 04:29 PM. |
| Bandpass formulas dilemma - newbie Q | grantnsw | Multi-Way | 14 | 11th August 2006 11:27 AM |
| Bandpass sub box | gregbutts | Subwoofers | 12 | 23rd May 2005 07:38 AM |
| boom box formulas.. | nbcd | Multi-Way | 0 | 22nd February 2005 01:50 PM |
| ported or bandpass box | lXxAndyxXl | Subwoofers | 22 | 3rd November 2004 02:41 AM |
| Page generated in 0.08113 seconds (75.83% PHP - 24.17% MySQL) with 10 queries |
