For the purpose of developing time-aligned LR xo, where is the best place to measure and check the reverse null?
- At tweeter axis, 1m - At midrange axis, 1m - At ear/listening height, 1m - or at listening position?
http://gainphile.blogspot.com |
#2 |
Is this a 2 driver two way? If so, set the mic 1m from the baffle directly between the center of the two drivers. MTM is a little harder because you have to put the mic at the tweeter axis, then account for the distance between tweeter and mid woofers.
#3 |
I have used to measuring like this and I'm happy with the result. I consider the tweeter very directive and I measure at the tweeter height. The reverse of the midrange of my big OB and the result is convincing ![]() - At midrange axis, 1m I never use this. - At ear/listening height, 1m Not easy to do. The height of the sit is very variable. And people don't have the same height. - or at listening position? Could be done only to measure the response but I think too much reflection to see a deep suck. |
#4 |
Do you necessary trying to to achieve/get a deep null in FR curve when the driver is connected in reverse? In some cases when you connect the drivers in correct order there a dip at the X-over frequency. I think some people will get, is this a more suitable response? or one should try to get a flatter response(not a bigger dip at x-over frequencies) when the measuring OFF-axis FR curves measurements ie horizontal and vertical dispersion measurements should do not deviate too much from on-axis measurements. I use this approach I am happy with the sound. I think this area should be discussed further. |
| Null Test | tbrooke | Pass Labs | 6 | 12th May 2009 03:51 PM |
| LR 4th order vs LR 8th order crossover | redliner | Subwoofers | 1 | 7th January 2009 11:32 PM |
| How to interpret reverse null? | Jay_WJ | Multi-Way | 7 | 11th April 2007 12:36 AM |
| LR xover question | steverb | Multi-Way | 12 | 20th April 2004 09:12 PM |
| output LR filter | Helix | Solid State | 7 | 8th February 2002 12:08 PM |
| Page generated in 0.09273 seconds (72.42% PHP - 27.58% MySQL) with 10 queries |
