i have recently bought a set of 2 bass drivers, and 2 tweeters for us in a car. the tweeters are about 1" accross (inside plastic housing so i cant see), and the bass drivers are approx. 8" with built in metal grill. i do not have any info for these drivers, and they have no name. i bought them from LIDL (spelling?), which is a suppermarket in england, for £10
, which i thought was good, even if they were rubbish.i wish to use the bass drivers in a subwoofer/subwoofers. how can i find the approx. box size required? the drivers are 4 ohms. thanks a lot.
If it aint broke, don't fix it. If it is broke, fix it. If you can't fix it, take it apart and see how it "worked". |
#2 |
hi matt, for determining the thielle-small parameters try rod elliott's site www.sound.au.com he has a very good article on that, and then just use winisd to determine the box size and type.
good luck |
#3 |
do i really need to do all that? do i need to find all the values? cant i just guess how big the box should be?
#4 |
you need those parameters if you want a good sound out off those speakers, otherwise you will spend a lot of time and effort with nothing to show for it
#5 |
ok, i have all the equipment, just not the time, ill have to make some though.
#6 |
good luck and i hope we hear about how things went
cheers |
#7 | |
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#8 | |
no, i noticed that when the page didnt load and i looked at the address bar.
| Beryllium drivers on the cheap?? | NV&H | Multi-Way | 7 | 19th August 2007 12:09 AM |
| Cheap little Sony Drivers | Smokehouse Bob | Full Range | 9 | 30th January 2007 01:18 AM |
| WTB: 269-469 ("1$ Parts Express") drivers, or other really cheap FR drivers. | Spasticteapot | Swap Meet | 1 | 5th November 2006 03:31 PM |
| BIB with cheap fr drivers, help needed | fcj | Full Range | 6 | 18th August 2006 09:38 AM |
| drivers for cheap | Iron Byron | Swap Meet | 0 | 27th August 2002 05:39 PM |
| Page generated in 0.11310 seconds (67.69% PHP - 32.31% MySQL) with 10 queries |
