Old 12th June 2010, 06:08 AM   #1
Default Open space distance for measurements?
I'm trying to recall how to calculate the lowest frequency you can measure reflection free.
For instance, let's say I mount a speaker in a 3m ceiling, and place the mic 1m away. Let's suppose this is a huge empty room, so the only reflection is the floor. Assume the speed of sound is 345m/s.
The direct sound hits the mic after 1/345th of a second, the reflected sound travels 5m and arrives at 5/345ths of a second. So the reflection free zone is 4/345ths of a second.
Then my brain gets stuck and can't remember. If the 4m reflection free corresponds to one wavelength, the frequency would be 86.25 Hz, and an FFT could get you valid data every 86.25 Hz. A swept tracked sine would be good above 86.25 Hz. Is that really correct?
Old 12th June 2010, 11:02 AM   #2
SY's Avatar
Not quite. That will set the lower limit for the measurement (regardless of whether it's swept, FFT, MLS, whatever), assuming you gate out the reflections. The frequency resolution of the measurement depends on the number of samples within the measurement period.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 12th June 2010, 02:29 PM   #3
ente is offline ente  Germany
Default Ap4
... have a look on this paper
http://www.fesb.hr/~mateljan/arta/Ap...d-Rev03eng.pdf
Heinrich
Mic distance for driver measurements ted4412wilt Software Tools 5 17th December 2009 08:35 PM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
CD player Drawer open close open close open close qguy Digital Source 7 23rd November 2006 08:58 PM
I need space. kiowamec Multi-Way 3 22nd May 2006 06:26 AM
Not enough space? WhtCastle Everything Else 7 28th November 2001 02:46 PM
Page generated in 0.08228 seconds (68.72% PHP - 31.28% MySQL) with 10 queries
