Old 10th June 2010, 07:27 PM   #1
Default Any one tested these speakers
http://cgi.ebay.com/2-GMI-PRO-6-1-2-...item2303cbc2c5
Specs look good but only a RTA test will tell if they have any usefullness
Old 11th June 2010, 12:20 AM   #2
tinitus is offline tinitus  Europe
Why do the write die cast alu chassis when its clearly pressed steel, from the picture
Old 11th June 2010, 03:54 AM   #3
gooki is offline gooki  New Zealand
I wouldn't touch them, specs seem fake, and GMI Sounds product range doesn't inspire confidence.
Old 11th June 2010, 05:02 AM   #4
Patrick Bateman's Avatar
Originally Posted by mcmahon48 View Post
(2) GMI PRO 6 1/2" CLOTH EDGE BULLET MIDRANGE WOOFER - eBay (item 150387540677 end time Jul-07-10 09:53:46 PDT)
For that kind of money, you could get a midrange with shorting rings and a cast frame from B&C.
If it was $10 I'd take a bet on it, but for $86, no thanks.
Old 11th June 2010, 01:24 PM   #5
GM is offline GM  United States
GM's Avatar
My limited experience with them is that they're pretty good, but that was decades ago and things change, so contact them to see if they will send you some real tech data: GMI Sound : Contact Us
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th June 2010, 01:54 PM   #6
prickears's Avatar
Does the cheap cap come free?
Pressed frame, can't flush mount, OTT (sus) specs, US$86. Just a hunch, but I reckon you could do better.
Maybe Good, (doubts), but if not, alot of dough for a paper weight and a cheap cap.
Making stuff 'idiot proof', Just breeds more effective idiots.
Old 11th June 2010, 04:05 PM   #7
chris661's Avatar
Definitely exagerrated specs. 99dB@1w, then down to 66Hz? Not going to happen with a driver that small. Eminence does a 6" driver with similar sensitivity, but it won't go past 100Hz.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 11th June 2010, 04:40 PM   #8
GM's Avatar
No way to know without specs, though it does imply a very strong motor and/or the strong break-up modes of drivers designed to mate to compression horns, which considering the source seems probable, making its sensitivity closer to ~93 dB/m.
Regardless, raw driver efficiency, sensitivity specs do not imply that it will be this over it's entire BW, only in it mass controlled (~flat) BW between its HF mass corner and break-up modes BW if the manufacturer/seller is being truly honest.
GM
Just tested the new E183CC piero7 Tubes / Valves 13 17th August 2009 05:18 PM
pictures of testing station and speakers to be tested mcmahon48 Multi-Way 1 15th February 2009 01:13 PM
Anyone tested Firefox 3? peranders The Lounge 11 7th June 2008 10:22 AM
Tested my new sub and no sound Emprov Subwoofers 1 24th April 2006 12:51 AM
"White Van" junk speakers tested, dissected: GrahamnDodder Multi-Way 7 19th March 2004 02:43 AM
Page generated in 0.14135 seconds (59.29% PHP - 40.71% MySQL) with 10 queries
