The last bandpass (4th) enclosure I built sounded bad, embarrassing even. The transient response just didn't work. I think I may have strayed beyond the drivers comfort zone.
I know about the gain/bandwidth tradeoff but is there such thing as the "appropriate" response for a given woofer? Is there a "best" closed volume that I can relate to standard closed box design? Put another way, for a given bandwidth and box size constraint, is there an "ideal" Thiele/Small set to look for? |
#2 | |
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
Thank you, GM. I've run a sample driver through the first page of mlutil to see how this works.
I assume you're suggesting that the resulting front/rear cavity volumes will produce the optimum loading for that driver? and any other response from that driver would be "less than optimum" I assume I can ignore 'M'? Why does it give me a 'new upper f3' when I already told it where I wanted it to be? and, will I need to guess and work out the front chamber tuning frequency? |
#4 |
You're welcome!
When combined with the vent's loading, correct. I can't run mlutil to play with it, but IIRC it only designs a horn based on driver specs hence the new Fh3. In his papers though, ML also rearranged mlutil's math to calc the driver's specs for a given horn alignment. 'M' defines the horn's flare factor, so can't be ignored, especially when accurately flaring the vent, though some say a simple radius round-over suffices. At this point though, I'm thinking that without a better understanding of horn theory it's probably best to just use a simple BP designer and try different driver specs. Note that for a 4th order max flat you want both the front and rear chamber to be tuned to the same frequency. From this we see that regardless of the alignment, the BP's mean tuning frequency will track the 'sliding scale' roll off response of its 0.707 Qts sealed one and all the design variables to get the desired eff./gain BW that this implies. GM
#5 | |
The reason that I ask is that i've built a *lot* of bandpass boxes. And they all sounded sub-par until I learned how to properly measure the impedance curve, and tune accordingly. The bad reputation of bandpass boxes is mostly due to mistuning IMHO.. And whatever you do, don't EVER rely on the predictions from programs like WinISD. In the real world, loudspeaker ports are WAY too complex. You *must* measure the impedance to get good results. |
#6 | ||
No, my last design was some years ago and was just a way to force a response from a driver. I realise I've been looking at BP through jaded eyes since. So should I start with the two volumes from leach, mount the driver in the rear chamber, measure fc, assemble the front enclosure and choose a port to match fb to fc? Quote:
#7 |
WinISD Pro is pretty good and WRT vent length for a given alignment it matches HornResp. Unibox is said to be good also. The most accurate I've used though is MJK's MathCad software. It's a pity he dropped his FLH WS as it does a great job of matching ML's predictions, ditto 4th order BPs.
Play with sims first, then do as PB recommends. BTW, WRT minimum vent area, calculate it the same as you would for a BR of the same net Vb, Fb for 'x' max power at < 5% mach (~17.2 m/sec). GM
#8 |
GM, finding drivers here is not terribly easy. Would you perhaps know of a few drivers that are 8" units with Qts less than 0.25, Fs less than 25-30Hz and Vas less than about 1'^3(28L)?
#9 |
The only one that comes to mind is the popular MCM 55-2421 that Bill F. uses in one of his FLHs, so do a search to get a variety of measured specs, performance info.
GM
#10 | |
If neither of those options is available, you might check out Image Dynamics. It's going to need a bigger box than the MCM, and it costs more than twice as much. But it also handles more power, and has more than twice the xmax. ![]() ID8V.3-D4 - Image Dynamics ID 8" Subwoofer Impedance: 2/8 Ohms Resonant Frequency 24.7 Hz DC Resistance 1.95/7.8 Ohms Electrical "Q" .367 Mechanical "Q" 3.572 Total "Q" .332 Equivalent Volume 1.55 cuft(44 liters) One way linear 15 mm Cone Area 231 cm2 Sensitivity SPLo: 85.6 dB Power Handling 150W RMS/300W MAX Power: 50-350W RMS XMax: 15.5mm Sealed ft3: 0.40 Ported ft3: 0.75 Mounting Depth: 4.75" Last edited by Patrick Bateman; 14th June 2010 at 03:20 PM. |
| 4th order bandpass, wheel well design :) (design inside) | TWOJZ | Car Audio | 28 | 13th January 2008 02:56 PM |
| Page generated in 0.11670 seconds (80.42% PHP - 19.58% MySQL) with 10 queries |
