I'm trying to understand what happens to a wave when it leaves a speaker. I believe that as a wavelength becomes small for the piston creating it, the radiation beams in a forward direction. From what I've read this might be because the piston pushes it that way.
On the other hand, as the wavelengths increase, the sound reaches out to the sides more. I'm guessing that this happens because distance sound travels during a cycle is greater. It has the chance to reach out during the cycle, like the woofer is acting more like a point source. Am I on the right track? To help me understand this, my question is...at higher frequencies where the woofer is beaming, does the sound wave actually touch the front baffle or simply launch away from the cone? or some combination? In a somewhat unrelated question, does sound maintain its SPL over distance in an ideal wavetube? |
#2 |
Here this might help you visualize what happens. Here is a software generated polar response on a 12" woofer.
Rob
"I could be arguing in my spare time" Last edited by Robh3606; 9th June 2010 at 12:12 AM. |
#3 |
Thanks Robh3606. I guess what I'm really trying to understand is the dynamics of the wavefronts... and how they pertain to baffle design and baffle treatment.
#4 |
Think of pressure waves being launched from every point on the diaphragm. If the diaphragm is larger, the distance from each point to your ear can vary by more than if the diaphram is smaller. When the wave from one "point" arrives so late that it has delayed by half a wavelength (pressure forward becomes pressure backward) relative to the pressure wave from another point, the opposite pressures from the two points cancel and no net pressure is left. At lower frequencies it takes a larger size (and difference in travel distances) for this kind of thing to happen. (this is a rather simplistic view, but I think contains the essence). WHen you are directly on-axis, the distance to every point is "most equal"
#5 |
For the baffle, look at it slightly differently. Imagine a pressure wave going across the baffle. It can't go into the baffle, since that isn't compressible, so it rides out across the surface. Until it reaches the edge, where suddenly it is able to be relieved by going around the edge. This is equivalent to a pressure wave of inverse polarity being launched at the position of that baffle edge. The pressure there is reduced, which is the same as suddenly adding an inverse pressure to a non-inverse pressure. So that negative pressure wave propagates toward the listener as if it were another source. And of course, the distance from the driver to the edge will have different effects (launch an equivalent wave of different size and phase shift) depending on the frequencies of the wave being discussed.
#6 |
One of the things I'd like to know (or preferrably understand
I think you're saying that these point sources radiate omnidirectionally and the lobing is all about cancellations. |
#7 |
I was reading something from Earl Geddes about this.
Notwithstanding my lack of understanding (and my paraphrasing ) I think he said that if the wavelength fits on the diaphragm it would be pushed only forward. This was a compression driver.
#8 |
Paul Falstad's ripple tank simulator is useful for understanding diffraction.
I wrote a simulation of a flat baffle with a flat cone driver mounted on it, with a sealed back (no rear radiation). This simulates a typical sealed back tweeter on a baffle. To use it, open this Web page: http://www.falstad.com/ripple/ If you have Java enabled, an applet window should open with a wave animation in it. Click "Stopped" Click "Import / Export" Click "Clear" Paste the following 7 lines into the window: $ 0 160 10 3 false false 15 15 600 1 s 85 128 s 115 128 c 25850 0 w 100 0 l 100 c 13950 0 Click "Import" Untick "Stopped" Vary the source frequency slider to see what happens. I find it helps to click "Clear Waves" after moving the frequency slider by a large amount. |
#9 |
That app helped me to "see" what was happening. It does look like the points are omnidirectional and the beaming has to do with cancellation.
(Just thinking aloud) looking at Robh3606 plot it looks like anything above 4K doesn't have any energy at 180 degrees and anything below 640Hz is fully omni. |
#10 |
Don Hills, is it possible to use this wave simulator to show a horizontal cross section (looking down) on an 'H' frame?
| Seen any driver beaming studies? | cuibono | Multi-Way | 17 | 24th November 2009 06:33 AM |
| beaming? with a large Full range with wizzer | pforeman | Full Range | 0 | 10th May 2009 12:34 AM |
| beaming? with a large Full range with wizzer | pforeman | Full Range | 0 | 10th May 2009 12:24 AM |
| What exactly is beaming and why does it matter? | paulspencer | Multi-Way | 101 | 12th June 2006 11:29 PM |
| Is beaming affected by volume? | Cal Weldon | Multi-Way | 4 | 13th November 2005 12:46 PM |
| Page generated in 0.46459 seconds (21.64% PHP - 78.36% MySQL) with 11 queries |
