Questions about time alignment and step response
Old 8th June 2010, 12:48 PM   #1
hasselbaink is offline hasselbaink  Denmark
Default Questions about time alignment and step response
What does it take to get good step response? (And time alignment I suppose)
I have read John Atkinsons article in Stereophile concerning speaker measurement and I was intrigued by the excellent step response of the Vandersteen seen here:
Having had quite a lot of listening experience with the Quad ELS67 which has a similar excellent step response and I was hoping to achieve something similar. You can say I am trying to catch some of the Quad magic without the drawbacks.
The Quad has no XO and the Vandersteen uses 1. order filters only - now assuming the higher frequency drivers are recessed or aligned with regard to the woofer - is 1. order filters the key to a good step response?
My own speakers have an asymmetrical 3. order/1. order network for the midrange-high frequency section at 800 hz, drivers connected in phase. The problem is that no matter how far back I move the high frequency section I still cant get a proper step-response. There seems to be two positive going peaks at all time, even though the last peak gets smaller af I move the tweeter back.
I am wondering if the 3. order/1. order network is the culprit here...
Does anyone here have knowledge about the subject?
Best
Kris
Old 10th June 2010, 07:39 AM   #2
*Bumpety bump*
C'mon - at least somebody's got to have an opinion on the subject.
Old 10th June 2010, 09:57 AM   #3
Inductor is offline Inductor  Portugal
Inductor's Avatar
Without measuring it is going to be difficult to find. What is possible is simulating a similar situation knowing the basic specs of drivers and crossover detailed circuit diagram.
Old 10th June 2010, 10:18 AM   #4
john k... is offline john k...  United States
john k...'s Avatar
STep response, impulse response, capability to reproduce a square wave are all dependent on the typ of crossover as well as the alignment of the drivers. See this article.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 10th June 2010, 10:50 AM   #5
norman bates is offline norman bates  United States
norman bates's Avatar
far as I know, 1st order is the only way to go, followed by a tricky baakgard crossover (filler driver, used by B&O a while back).
24db, while touted as time alignment, is only aligned at the crossover point.
I have a old pair of thiels (6db, slanted baffle). They are good but lack in many other areas. Sometimes I use a pair of 4" run wide open with bass support, sometimes I cross them at 400hz (24db LR) to a pair of 15's, and most of the time I cross 15's to a compression driver (750hz @ 24db LR).
Norman
Old 11th June 2010, 07:42 AM   #6
Default STep response, impulse response, capability to reproduce a square wave
Thank you very much John,
I am going to read this article carefully again even though some of the math is beyond my current level of understanding.
I am willing to sacrifice perfectly flat frequency response in order to obtain better transient response and better time alignment.
I will post some measurements that apply to the midrange/high frequency section of my speakers. This section is passively filtered - the XO is ~800 Hz, asymmetrical electric slopes. It is easy to move the horn loaded tweeter section independently of the bass/mid driver.
Measurements will be posted at a later date. (As soon as possible).
Sincerely
Kris
Old 11th June 2010, 06:32 PM   #7
john k...'s Avatar
There are actually many ways to achieve transient perfect crossovers. Theyt don't always lend themselves to passive desings though. Additionally it is difficuly to conclude what the audible effects are since in most cases the polare response of the system will also change. It in only when we get into the use of digital crossover and digiutals pahse correction that we can control the transient response without altering the polar. Then, and only then can a meaningful comparison be made.
Old 12th June 2010, 05:48 AM   #8
head_unit is offline head_unit  United States
Originally Posted by hasselbaink View Post
...I am willing to sacrifice perfectly flat frequency response in order to obtain better transient response and better time alignment...
Mmmm, OK, but I think actually the two should go hand-in-hand.
My feeling is this is hugely dependent on choice of drivers. The drivers must be well behaved and lend themselves to a simpler crossover.
What Vandersteen model is that step for? Which Stereophile issue?
Old 12th June 2010, 10:25 AM   #9
David Gatti is offline David Gatti  Australia
David Gatti's Avatar
In a nutshell, you basically need 1st order crossovers on all drivers, and proper time alignment.
In reality, this can only be approximated as driver rolloffs, frequency dependent acoustic-centres, and falling off-axis responses make it virtually impossible to achieve.
Still, as a purist who believes simpler is usually better, it's something I aim for in my own designs.
Old 17th June 2010, 03:24 PM   #10
ds21 is offline ds21
One thing to also mention is we are talking 1st order acoustical, and achieving that can actually end up being a complex crossover with a lost of components.
True Creation Comes Out Of Nothingness
Questions about time alignment and step responseHide this!Advertise here!
Time alignment jmar Multi-Way 7 1st January 2010 02:51 PM
stuffing Mileva: first timer step by step questions schro20 Full Range 7 2nd June 2008 05:49 PM
time alignment? flaevor Multi-Way 7 18th August 2006 12:51 PM
is doing time alignment now a waste of time? Beggar Multi-Way 9 28th July 2003 05:45 AM
Time alignment circuitry Xylenz Multi-Way 4 11th October 2002 12:46 PM
