Given that you horn load a driver, and uses, for instance, a cap to deal with the horn loading, will this break the gained dynamics by using a horn?
Cheers |
#2 | |
What gained dynamics do you mean? A horn doesn't increase dynamics, it just plays everything louder. So you may turn your volume control down and/or use a lower power amp. Is that what you mean? How would you connect the cap? Is it part of the crossover? Do you mean a capacitor or a mechanical cap somewhere? jd
/Another new issue: Linear Audio Volume 3! |
#3 | |
From my experience, perception of dynamics is all about sensitivity. A horn boosts sensitivity, meaning increased dynamics, but I wonder, if one attuniates the horn loading back to the nominal sensitivity of the driver, is the increased dynamics gained by the horn lost? |
#4 |
Dynamics are the difference between the loud and quiet parts of music. Whether or not your driver is horn loaded is irrelevant. As has been stated: a horn makes everything louder. Right across the frequency range. If you add a capacitor, then you'll get an uneven response, but the volume available from the horn will be the same (provided, of course, your capacitor is rated for it).
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#5 | |
It doesn't do anything to dynamics, except when you equate dynamics to sensitivity jd
#6 |
No it doesn't effect the dynamics at all. Where it potentially could be a problem is padding down a horn loaded compression driver to match a low sensitivity woofer. If you pad down the horn and don't take that padding into account you could potentially under power the horns driver with most of the power dissipated in the network. Not that likely unless you use under 10 watt amps.
Rob
"I could be arguing in my spare time" |
#7 | |
#8 |
#9 | ||
When you attenuate the driver all you are normally doing is limiting the maximum SPL level. You are changing the nominal 110db@1 watt down to the woofers, say 90 db. So you have a 20db pad and 1/100 the power available to the CD. The compression driver is still capable of delivering it's full output providing the rest of the system can survive the input power required to negate the power lost in the network. All you are really doing is changing the set point so to speak of the compression driver, all else remains the same. You are not changing the capabilities of the driver. I have a couple of systems using padded compression drivers and they sound darn good. Rob
#10 | |
| Horns inside of horns open foe discussion | oilcanracer | Multi-Way | 3 | 15th February 2010 03:42 AM |
| Dynamics in Loudspeakers | gedlee | Multi-Way | 181 | 8th October 2007 08:31 AM |
| smith horns and using compression horns for a Karlson party speaker project | bikehorn | Multi-Way | 10 | 27th December 2005 09:10 AM |
| Horns: Vibrations and resonances in metal horns | Rocky | Multi-Way | 10 | 28th July 2004 01:38 AM |
| breuer dynamics | pamaz | Analogue Source | 17 | 7th April 2004 07:22 PM |
| Page generated in 0.14570 seconds (79.21% PHP - 20.79% MySQL) with 11 queries |
