Hi all - I just obtained a pair of Pioneer HPM-100 speakers in near mint condition. The price was right - free. Mt brother-in-law was made to give them up due top their size! As I said, they are almost in near mint condition - the cabinets shows their age - but this is cosmetic. The only other issue I can find with them is that one of the tweeters sounds a little off - distortion at high volume. I would like to replace both of them with new units and am looking for suggestions - something that would match physically, electrically and acoutiscally. Any suggestions ? Could the issue be related to a bad capacitor or other crossover component ?
frank |
#2 |
Speakerholic
Hi Frank,
Check to make sure it's not one of the L-pads by rotating the knob back and forth. If it turns out to be that you need some anti static spray or in a pinch WD-40 (Gasp!) Replacing a tweeter other than the original can be a little tricky. EDIT: You said it was at high volume so you're probably right so the second thing to do is pull the tweeter and try turning it 180 degrees. Hopefully it's a misaligned coil that straightens itself out. It's a fingers crossed solution but sometimes by the grace of *** it works. |
#3 |
frugal-phile(tm)
You want to exhaust everything else before thinking about replacing those special Pioneer tweeters.
I'd consider replacing the (likely) electrolytic caps will poly as part of the diagnosis work. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Thanks guys - I will try out your suggestions and post back results
frank |
| replacement tweeters musical fideleity mc4 speakers | boredsurfer | Multi-Way | 9 | 7th December 2011 01:15 AM |
| Rega R5 tweeters replacement. Help. | Fusion123 | Multi-Way | 2 | 31st October 2009 12:03 PM |
| HELP! Trying to source replacement tweeters for TDL RTL3s | paulspencer | Multi-Way | 1 | 25th June 2009 06:40 AM |
| Acoustic Research LST replacement tweeters | Charles Wasserf | Multi-Way | 2 | 8th June 2008 02:28 AM |
| B&W DM-220 Replacement Tweeters | racedirector | Multi-Way | 2 | 14th September 2005 07:58 AM |
| Page generated in 0.06981 seconds (73.17% PHP - 26.83% MySQL) with 10 queries |
