I have always avoided full range drivers because I was under the impression that a driver designed to perform at a specific frequency will always outperform something more generic.
"Jack of all trades, master of none" comes to mind. Recently I ran across the Tang Band W8-1808B 8" Neodymium Full Range Driver. This thing looks pretty amazing on paper and whatever users here and elsewhere I can find appear to be very impressed. So far, nobody has had anything negative to say about it. Too good to be true, what's the catch? Before I place my order, are these really pretty darn good or should I be more skeptical? I'm considering ordering a set and a 15" woofers to support the lower end in a 2 way OB design for 5.1 HT. |
#2 |
Really? I thought I'd seen some negative comments here and there. Mostly in the Full-Range section. Maybe not....
And there is this new thread about the other TB fullrange. Open Baffle Project w/TB 1772 and AE OB15's
Take the Speaker Voltage Test! |
#3 |
Yeah, I just saw that come up right after I posted.
Following closely. A while earlier I was set on planars but now I'm hesitating. Long thread about the 1772 I'm still reading here: Tang Bang W8-1772 Impressions. |
#4 |
Open baffle 5.1 system? You must have a really big room.
#5 |
I see your point and I was hoping the 15' x 30' room is big enough. If it won't work I'll just go with a ported enclosure instead. Already modeled a few options I think would work as an alternative.
Have my heart set on OB for a unique HT experience but it's not absolutely necessary. |
| Tang Band W8-1808 Cabinet | majerjack | Full Range | 30 | 5th September 2010 02:41 AM |
| FS: Tang Band W8-740C Subwoofers | nic6paul | Swap Meet | 2 | 31st January 2010 04:17 AM |
| FS: Tang Band W8-740C | HTRookie | Swap Meet | 0 | 1st August 2009 06:57 AM |
| Tang-band 2-way (W3+W8) | haffe | Multi-Way | 10 | 31st January 2007 11:11 PM |
| Tang band W8-740C FS .... | jhammer221 | Swap Meet | 5 | 24th March 2006 01:34 PM |
| Page generated in 0.09914 seconds (77.25% PHP - 22.75% MySQL) with 10 queries |
