Old 1st June 2010, 02:17 PM   #1
asiquis is offline asiquis  Canada
Default Gazebo sound options
I have a 12x12 ft gazebo (octagon shaped) to get some sound to.
I will be using an older 50 watt x 2 channel amp for power.
I have 4 Clifford Design 6.5" coaxial car audio speakers NIB
60 watts RMS (each)
sensitivity 89dB @ 1w/1m
4 ohm
frequency response 45-20,000 (does not show +/- dB)
4.7 uf cap on tweeter
Now the questions:
1) If I wire 2 of the speakers in parallel for Right channel and the same for the Left channel I will have an 8 ohm load for each channel right?
2) will this affect the SPL of the speakers?
3) would I be best to just mount each on a baffle at 4 equal distant points in the gazebo roofline since I do not have the t/s parameters for boxes?
Or might it be better to build one speaker such as this:1)
If I were to get a dual coil woofer (8 ohms per coil) one coil wired of Right Channel and one coil wired for Left channel and run 2 tweeters will I get a form or stereo from one box?
I was looking at the new Atrium series from Polk as the inspiration....
2) If the woofer is 87.7 dB at 1w/1M will that be the SPL to match thetweeters up to?
3) I was looking at the MCM MCM Audio Select 8'' Dual Voice Coil Woofer | 55-2185 (552185) | MCM Audio Select
crossed over at 1500-1800 4th order slope as per Zaph's suggestion for this woofer on his site and mated with 2 appropriatly low fs tweeters possibly the Dayton
Dayton DC28F-8 1-1/8" Silk Dome Tweeter | tweeter dc28f-8 silk dome tweeter dome tweeter soft dome dayton audio dayton loudspeaker dayton dayton silky daytweet-41108 daytontweets090109 last_chance_save_green | Parts-Express.com
The box would be 18 liters tuned to 40-45 hz
Any comments and help would be appreciated.
Or go with plan A ?
Old 1st June 2010, 03:13 PM   #2
Speedskater's Avatar
For question:
#1 Wire them in "series" not "parallel"
#2 In general with 2 speakers sharing the sound you will get an increase is SPL. But this can become a definition issue with different people using different setups.
Kevin
options please brucegseidner Power Supplies 3 5th February 2010 01:39 AM
Sheilded options for 2 way or 2.5 way UK Dave Multi-Way 4 21st April 2008 06:46 AM
CD Options? renfrey Digital Source 1 5th March 2007 08:18 PM
Fe126 options daveingu Full Range 14 19th December 2006 10:48 PM
case options clearwaterms Chip Amps 2 5th December 2006 07:14 PM
Page generated in 0.06613 seconds (75.56% PHP - 24.44% MySQL) with 10 queries
