Old 29th May 2010, 05:09 PM   #1
oLjud is offline oLjud  Sweden
Default OB quasar mkII - filter question(s)
Hi all OB-fans!
I'm thinking about building the Quasar mkII, find the speaker very interesting (like the design alot! ) but I have some questions about how to solve the crossover issue I've got.
All configurations so far i've seen/read have used active filter for Alpha 15", but i currently not an owner of a activefilter.
So my question is: is it possible to build a passive filter for the speaker instead? Or will it be as expensive as to buy an active filter?
Any inputs?
Best regards
Mikael
Old 29th May 2010, 06:00 PM   #2
jerome69's Avatar
It is possible if you use the alpha 15. See MJK papers : OB Theory
Solid state amplifiers required.
Regards.
Old 29th May 2010, 06:58 PM   #3
Thanks for that link, had totally missed it.
Since he's only using 1 15" and I'm using 2 15" I should only lower the coil from 9mH to 4.5mH for same results, right?
best regards
Mikael
Old 29th May 2010, 08:09 PM   #4
jerome69's Avatar
Yes the coil to 4.5mH and the capacitor to 2x68uF.
Regards.
Old 29th May 2010, 08:12 PM   #5
Thanks for the answer. Just had to double check
Service Manual Request: Marantz CD75 MkII or CD65 MkII jeff mai Digital Source 9 23rd April 2009 04:48 PM
buscchorn mkII stuffing question fergs1 Full Range 2 11th January 2006 07:18 AM
Perspex Quasar James D. Multi-Way 18 10th January 2006 09:28 PM
Question on Eros MKII tweeter to woofer separation andy2 Multi-Way 2 9th October 2005 04:18 AM
Thorens TD 124 MKII question louis Analogue Source 3 2nd July 2003 03:27 AM
Page generated in 0.07663 seconds (71.81% PHP - 28.19% MySQL) with 10 queries
