Old 28th May 2010, 02:11 PM   #1
Default Question About Vintage Drivers
Hi all. On some older woofer/midranges, I've noticed a ring of cork about 1/4" thick encircling the woofer at the edge of the surround. The Spica TC-50 woofer is one example.
Does anyone know what this is there for? I'm guessing that it's used as a gasket for non-flush mount configurations maybe? Basically, I want to know if this can be removed to reduce any potential diffraction effects or would that compromise the driver. Thanks.
Old 28th May 2010, 02:13 PM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
It's there as a gasket, correct. You could pull off the surround adhesive if you weren't careful, but you're probably okay to remove it. Cork is absorbtive however, so probably no real benefit to be gained.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 28th May 2010, 02:20 PM   #3
Thanks for the quick response! I think I'll let it ride.
Old 28th May 2010, 04:39 PM   #4
kevinkr's Avatar
Good decision..
www.kta-hifi.net
Can anybody identify these vintage drivers? Jim85IROC Multi-Way 3 15th February 2012 03:07 AM
Identity of two vintage drivers? Brisso57 Multi-Way 3 18th November 2008 03:42 AM
vintage ROLA drivers aardvarkash10 Full Range 2 2nd April 2008 10:35 PM
Vintage German drivers...... JandG Full Range 5 13th September 2006 01:58 PM
Vintage OB Drivers inrank Full Range 5 31st August 2006 05:43 AM
Page generated in 0.06866 seconds (80.68% PHP - 19.32% MySQL) with 10 queries
