Hi All.
I was hoping someone could suggest a crossover design for a 6" 2-way I'm building as a graduation gift for my kid. I have no simulation software, so I'm asking for help. I've got two drivers on closeout order from Parts Express at very reasonable cost. The 6" woofer specs are: "Power handling: 80 watts RMS/160 watts max *VCdia: 1" *Le: 1.13 mH *Impedance: 6 ohms *Re: 4.47 ohms *Frequency response: 40-3,500 Hz *Fs: 64 Hz *SPL: 89 dB 1W/1m *Vas: 0.22 cu. ft. *Qms: 3.98 *Qes: 0.47 *Qts: 0.42 *Xmax: 2.5 mm " JAMO 20422 6" Treated Paper Cone Woofer 6 Ohm | JAMO 20422 6" Paper Cone driver Woofer speaker midrange mid jamo_buyouts_10C ccflippy | Parts-Express.com and 1" dome tweeter specs are: "Power handling: 50 watts RMS/100 watts max VCdia: 1" *Impedance: 4 ohms *Re: 3.1 ohms *Frequency response: 1,000-20,000 Hz *Fs: 1,070 Hz *SPL: 94 dB 2.83V/1m. " Vifa BC25TG19-04 1" Textile Dome Tweeter 4 Ohm | Vifa BC25TG19-04 Tymphany DU0207 BC25TG15-04 BC25SG15-04 IC0465-01-1 dali Dome Tweeter 4 Ohm tweeter peerless vline waveguide hf high frequency mtm PeerlessBuyouts612010 | Parts-Express.com I already have the boxes, which have a baffle 15" High x 7.5 Wide with an edge chamfer beyond that. Thanks in advance for your assistance! -Chas |
#2 |
without an impedance plot it's impossible to design a good crossover.
I suggest you download ARTA: ARTA ARTA Download Make this simple jig: ARTA Jig - AudioBlog: A simple loudspeaker measurement jig for ARTA and you're in business...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#3 |
I should clarify:
I have the Jamo crossover for the Jamo woofer, which gives a 2nd order low-pass rolloff at 3kHz... I just need help with the high-pass for the substitution of this Vifa tweeter (impedance plot/link found here: http://www.parts-express.com/pdf/279-175s.pdf Thanks. -Chas |
#4 |
read off the impedance value at your xover freq & plug the numbers into this calculator:
Crossover Design Calculators Then work out the difference in dB between the woofer & tweeter and calculate an l-pad on the same calc page. That will get you close enough to get started, you can tweak from there. Specifically you may want to add baffle step correction.
#5 |
I finally got the woofer and tweeter measured, and also have a second tweeter option that may be more suitable.
Here's the (6" Jamo)woofer data: Last edited by clm811; 10th November 2010 at 07:39 PM. |
#6 |
Here's the Dali Tweeter data:
(May not be good match) |
#7 |
Here's the data for the Dayton 1.1" silk dome, which may be a better match to the Jamo woofer(any help is appreciated):
#8 |
The Dayton seems to be the same sensitivity as the woofer, has ferrofluid (better damping), & a lower Fs, probably much easier to use than the Dali...
Do you have a frequency response plot for the Jamo - to help with choice of crossover frequency? - Otherwise go for an LR 2nd order xover at around 1.5-2 KHz, the Jamo's impedance rises fairly quickly, so a zobel is probably in order...
#9 | |
With LR 2nd order crossover, must one invert the tweeter polarity connection for flat response? TIA -Chas |
#10 | |
And this crossover does not include a treble section ? Its the acoustic target at 3kHz that determines the tweeter phase, not the electrical filter order, see Zaphs designs. rgds, sreten. http://sites.google.com/site/undefinition/diy Zaph|Audio FRD Consortium tools guide RJB Audio Projects Speaker Design Works HTGuide Forum - A Guide to HTguide.com Completed Speaker Designs. Humble Homemade Hifi Click below to go to Quarter Wavelength Loudspeaker Design The Frugal-Horns Site -- High Performance, Low Cost DIY Horn Designs Linkwitz Lab - Loudspeaker Design Music and Design
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 11th November 2010 at 03:51 PM. |
| Peerless India Drivers cheap from PE | AdamThorne | Full Range | 11 | 20th April 2009 06:23 PM |
| Peerless 850136 On Closeout at PE | sdclc126 | Multi-Way | 5 | 6th November 2008 01:11 PM |
| Crossover appears to be off on PE amplifier | owdi | Subwoofers | 3 | 27th November 2006 02:32 PM |
| A few PE Dayton 3-way crossover questions... | ptwining | Multi-Way | 2 | 9th July 2006 12:50 AM |
| FS: PE subamp, drivers - Australia | rabbitz | Swap Meet | 2 | 6th April 2004 01:05 PM |
| Page generated in 0.15224 seconds (73.73% PHP - 26.27% MySQL) with 11 queries |
