Hi
I am currently designing a set of two way bass reflex speakers. My design is based on the Thiele-Small method. To design the enclosure one must choose a value for the enclosure loss, named Ql. One of my sources states that one should start with a value of Ql = 7, if the required volume is in the range of 2-3 cubic feet 7 is fine. If you arived at a smaller enclosure you should select a higher value and redo the calculations. Taking Ql = 7 I arived at a volume of 35 litres. The next graph that is availeble is Ql = 10. If you however use the functions provided in Small's paper you can use any value in between. Is there a more accurate way to choose a value for Q? Would using Ql = 10 in stead of Ql = 9 have severe implications on the design? Thanks Odie Malan |
#3 |
Downloading now, will work on it over the weekend. Cheers Odie |
#4 |
I checked and you can model Q of box and Q of vent.
Not sure how the values relates to losses in numbers. The effect should be the same I think. But if you want to model response and experiment then Basta! is one of the best IMHO. Cone excursion is in RMS and not peak though, not sure if it is mentioned anywhere but good to know. |
#5 |
Did it Himself
You don't know Ql until you build the box. My advice is build it and check Fb and Ql. If they are more than 20% off what you designed for then first listen and see what you think before amending the design. If less than 20% then don't worry about it. You can get all hung up on the numbers and simulations when in reality the differences aren't that massive to the ear.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
| Ql | bjackson | Multi-Way | 4 | 11th May 2012 10:53 PM |
| Full range driver & enclosure selection help | CrookedChris | Full Range | 36 | 26th August 2009 10:59 PM |
| HELP with driver selection for existing enclosure | fazman | Multi-Way | 4 | 26th October 2007 02:24 PM |
| Jvc Ql Y5f | graeme uk | Analogue Source | 0 | 18th February 2007 08:59 PM |
| bandpass enclosure woofer selection | Opie | Multi-Way | 1 | 21st September 2002 07:57 PM |
| Page generated in 0.09389 seconds (71.43% PHP - 28.57% MySQL) with 10 queries |
