hi guys,
this is the idea of my first diy borned after diving several months here here is the genaral information; hight, 950mm deepth, 350mm width, 450mm tweeter, scan 93000 mid, seas h1262 (5") woofer, seas h1316 (10") thanks, Last edited by diypwj; 27th May 2010 at 03:41 AM. |
#2 |
If you like it ,go for it ! Classic design is never boring .
You forgot to mention filter's characteristics : How ,when ,where ..!Are you going to "cut" the bass at around 300 Hz ? And the midrange at 3000 Hz? The crossover is the heart of the system. |
#3 | |
i wrote the units PN (espercially the woofer) and the details of inverted image tube, since i want to recieve any advise of the speaker internal size/structure, and any good experience of tube design. about the crossover i cut the base at 500Hz and midrange at 2600Hz. i haven't finished the circuit design so that's all. about the space at the bottom inside, i plan to fill it with sand, to achive better stability and to adjust the internal space size (from ~75L to ~65L) thanks |
#4 |
Hi ! yes ,the tall cabinet made me wondering ,too . Not knowing the size of the duct (diameter and length),but talking about it...You could do it with wood ,3 pieces of ,say, 7 X 20 cm attached together and to the rear wall of the cabinet.
Then you shape the 90° curve with many 7 X2 cm to get a smooth transition ,and the final touch would be to FLARE the mouth ...well ,also the beginning of the reflex duct should be flared . |
#5 | |
something like what shows in below picture, right? |
#6 |
Yes. I was meaning to make the duct square,using the rear panel of the cabinet as a side of the duct . A fold means losses ,it depends if and how the 10" speaker allows it.
#7 |
err...this could be the structure you are talking.
i'm not sure if it works, i haven't seen suchduct before. is it good? how to caculate its length and size? |
#8 |
yes ,you got it . Don't know if flaring is really a necessity ,since it may be a complication in construction , it is just to minimize air velocity in the vicinity of the entrance and exit of the duct . Which duct ,can be compared to a tube having its own length and section area.
I think it will have a square hole of 10x10 cm , maybe less ... |
| diy MESA pre as 3rd channel on guitar amp? - Need Advise! | Rswilliams | Tubes / Valves | 4 | 19th January 2010 02:26 AM |
| Looking for help and advise on DIY project. | trompie | Multi-Way | 0 | 23rd November 2009 10:58 AM |
| Please advise | WunHungLo | Multi-Way | 4 | 28th June 2004 10:38 PM |
| Advise on Diy Subwoofer amp | SlaitH | Solid State | 7 | 3rd February 2003 08:53 AM |
| Page generated in 0.10710 seconds (70.49% PHP - 29.51% MySQL) with 11 queries |
