First DIY speaker project initial concept - thoughts? - Page 2 - diyAudio
Old 27th May 2010, 04:49 PM   #11
joe58 is offline joe58  United Kingdom
Yeah sorry about the link forgot to put it in. Glad you found it, but it is possible just takes time and no rushing to get it finished, which can provide problems as you just wanr to hear the dam thing play.
Old 28th May 2010, 02:15 AM   #12
Originally Posted by james77 View Post
Can I ask where you got these prices, i really only know of partsexpress for decent prices for speakers.
Mostly Parts Express; they're generally the best option. They don't carry SB so I used Madisound's prices on those.
is there any reason i shouldn't use these?
See this for an intro; generally LR4 or steeper at about 2kHz is desirable to avoid cone breakup and directivity problems on a six inch woofer. That's also about as low as most tweeters will comfortably go. Easier and often cheaper to throw down a few Sallen-Keys and a couple extra 3886s than to get the impedance matching right in a passive crossover. Another relatively low cost option's buying something like an Ashly XR-1001.
Won't improve the iPhone's DAC any, but that can be dealt with separately.
Old 28th May 2010, 05:44 PM   #13
roger_lew's Avatar
I havent really looked into them before, but it would certainly keep things simple, do they perform well? im a little skeptical of 'full range' drivers but that is probably just cause i never used a decent one before.
I haven't heard the CHR-70 drivers. I do have a pair of CSS wr125st drivers, and I think they are quite the performers.
The CSS fr125sr runs $49 each. The SDX7 runs $100 each. If you got 2 of each that would put you at $300 but you can cross them with a single inductor and cap and you wouldn't need a separate amp dedicated for bass (see here) or go active given your background.
The SDX7 will work in a sealed enclosure as small as 14 liters (A thread for Tysen and variations on FAST).
Roger
Old 31st May 2010, 03:47 AM   #14
james77 is offline james77  Australia
Its been a busy couple of days...
I have been looking at pasts express - good prices until i add shipping to Australia over US$90 to ship (about 100 aud) and i wanted to get everything for around AUD$200 so i need to work out what will be best for me ie import from us or buy local. The fr125s look pretty good.
Have you had much experience with visaton drivers? (i ask because i can get them locally for reasonable prices)
as for my existing crossovers im yet too have a close look at them to see what filter arangement they are - i belive they are 12dB but ill check them out.
thanks
Initial Thoughts for "Mr. Piggy" SE Amp w/Screen Driven 6P45S wrenchone Tubes / Valves 10 24th September 2015 06:22 PM
Initial Project: 300W Power Amp bharfhy Solid State 13 6th January 2010 09:25 PM
Speaker Workshop - Pls Guide me through initial setup HiFiNutNut Multi-Way 4 18th November 2007 10:42 PM
Double Bass Array concept, any thoughts? thadman Subwoofers 0 1st May 2007 03:39 AM
First DIY speaker project birddog Multi-Way 11 2nd September 2004 08:44 PM
Copyright 1999-2017 diyAudio
