Old 26th May 2010, 12:13 AM   #1
Salsero is offline Salsero  United States
Default Tube friendly OB Designs
Hi Guys,
After two succesfull projects (Tri-trix speakers and a simple SE tube amp), I am considering my third project to be an open baffle speaker. I would like to use a full rnage driver with a 15" woofer combination. Given that my tube amp is only capable of 16W, I need something that will end up at >90 db/W/m efficient.
On an aesthetics, I would prefer a very thin design when viewed from the front. In the ideal, I would like to approximate speakers floating in the air. I just think that would look cool.
Given that throwing ideas around is free, I thought I would ask for some recommendations.
Salsero
Old 26th May 2010, 12:20 AM   #2
I would try something like this
your 15 "ers on bigger pots.
Old 26th May 2010, 03:38 AM   #3
bigdh31 is offline bigdh31  United States
Any of MJ Kings OB designs should work fine.
Quarter Wavelength Loudspeaker Design
Old 26th May 2010, 03:50 AM   #4
Pano is offline Pano  United States
Pano's Avatar
Tube friendly mids and highs you can do on OB all day long. 90dB/watt is not a problem with the right driver and baffle.
Tube friendly bass, not so easy. You'll need a lot of surface area for the baffles and the cones. It can be done, but not in a minimalist way. It takes surface area and displacement.
However, why not choose the best of both worlds? Use tubes up top for the mids and highs (could be the same driver) and solid state grunt on the bottom. It could be as simple as tubes on top and a plate amp on the bottom. Or even a bi-amped passive rig. An 18" is even better for bass in this kind of rig. Have a look at the Dayton PA460-8, or the Goldwood GW-1858. Both good woofers that will give you a different feel in the bass and will need different crossover techniques.
There are plenty of good OB designs around the forum. Seek and yee shall find.
Take the Speaker Voltage Test!
Old 26th May 2010, 04:25 AM   #5
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Try this...?
Get some 3/8" Plywood, cut two panels......40" wide, 20 " high ...Put this noted full-range 8" driver ($31 Ea.) in from the back. Wrap the whole front side in a light Mauve fabic, hang the assembly from the ceiling with forty pound test fishing line. Run a series of small hooks down the backside to get the assembly angled down. Set it up about face high 15-20" from the wall...or?
Run some 20 gauge white Zip-cord to the corners.
I did something like this in 1980 & it sounded great.
__________________________________________________ ______Rick....
Old 26th May 2010, 05:08 AM   #6
jerome69's Avatar
OB speakers are definitively not thin with a 15" ?
If you want a full OB speaker with 16W ... not possible. A solid state amplifier is needed at least 50W for the bass. And you can use the tube amplifier for the midrange.
An other solution, You can do a semi OB. Fullrange OB and Box for the woofer.
An example is here, sorry it's in french. Use google to translate
Have Fun
Old 26th May 2010, 09:48 AM   #7
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
This will be 90 dB+ from 80 Hz, 95 dB from 200 Hz:
More information: OB with Ciare CH 250. Move to the example with the glass baffle for dimensions.
Another OB with the same driver: Dacapo from Hobby Hifi 3/2006 magazine
This is with a Supravox 215 FR driver:
http://www.audioasylum.com/forums/hu...es/106274.html
www.dipolplus.de
Old 26th May 2010, 01:52 PM   #8
Pano's Avatar
Our buddy Rudolf is cheating!
He HAS big baffles for bass, but it does not LOOK like he has big baffles.
Clever design.
Old 26th May 2010, 02:02 PM   #9
JC Fardo's Avatar
Hi
Lukasz Fikus Lampizator
speakers, DIY, projects
JC
Jose Carlos
Old 26th May 2010, 02:27 PM   #10
el`Ol is offline el`Ol  Germany
Is this possible in your room?
Tube friendly speakers chrish Tubes / Valves 18 25th July 2008 01:44 PM
The ultimate tube friendly HE fullrange? AJinFLA Multi-Way 0 14th August 2005 03:49 AM
Tech challenge: neighbour-friendly high eff. designs? Karanael Multi-Way 6 3rd July 2005 07:35 AM
Suggestions on tube-friendly speakers? Eric Sprik Multi-Way 22 1st March 2004 09:34 PM
Page generated in 0.16407 seconds (55.15% PHP - 44.85% MySQL) with 11 queries
