Old 24th May 2010, 07:15 PM   #1
SunRa is offline SunRa  Romania
Default Rather unique coaxial?
I found this italian manufacturer, employing a 15 coaxial with a 3" compression driver. No this is looking very interesting as I haven't seen any similar coaxial before.
I am almost sure it's not 18Sound or Ciare, the two major italian speaker producers. Any thoughts on this?
Specifications
Old 24th May 2010, 08:17 PM   #2
Brett's Avatar
Looks nice enough.
The 3" for the CD is almost certainly diaphragm size so 1.4 or 1.5" throat.
Old 24th May 2010, 08:21 PM   #3
chris661's Avatar
The cabinet looks too small for 99dB/w at 30Hz...
Any opinions on this?
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 24th May 2010, 09:05 PM   #4
The cab looks like it has a nice finish.
If I'd buy/make something with a coax compoment the mids and high (unity horn or BMS coax) would be the coax component, not the low and high.
The coax could perhaps be a modded version of the B&C 15CXN76.
Don't know any other driver with such a big HF component.
Old 24th May 2010, 09:22 PM   #5
Speakerholic
Cal Weldon's Avatar
Many Coax's have 3" drivers. We usually refer to the size of the exit rather than the diaphragm, hence the confusion.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 24th May 2010, 11:04 PM   #6
To be complete; I couldn't find a lot of 15" / 3" Diaphragm coax'es currently available, the one I mentioned has a 3" dia, no info on mouth exit mentioned. Curious to see what 'this' driver will actually be.
Old 24th May 2010, 11:12 PM   #7
jwmbro is offline jwmbro  United States
jwmbro's Avatar
Reminds me of the 12" Coaxial in the new Tannoy top of the range speaker (can't remember the name of it)
Old 24th May 2010, 11:40 PM   #8
In principle it reminds me of any Tannoy DC made in the last 50 or so years.
It looks like a cross between a Glenair and a TD12.
Old 24th May 2010, 11:43 PM   #9
In fact, the only 3" exit driver that seems to be uot ther is the JBL 2490H? :S
What could this coax be or do they mean 3" dia in their specs?...
Old 24th May 2010, 11:57 PM   #10
Inductor's Avatar
Yes, maybe a super-tweeter (Fostex?). The same problem, here, with Tannoy Dimension TD12.
Last edited by Inductor; 25th May 2010 at 12:02 AM. Reason: http://www.stereophile.com/floorloudspeakers/1103tannoy/
Unique Autosports JDDCo Car Audio 19 15th January 2009 01:19 AM
My new unique (i think) DIY project (pics!!) Shpoop Multi-Way 33 27th June 2007 05:01 AM
Please help me find the part I need for this unique application! Gveto Parts 3 25th March 2007 05:03 PM
Is this a unique design or am I still that much of a novice? MrGuitardeath Solid State 2 19th November 2005 04:37 AM
Page generated in 0.11513 seconds (73.88% PHP - 26.12% MySQL) with 11 queries
