I am thinking of putting a seas w15cy001 and a hiquphon OWI in a wide (curved) baffle. The speaker will be approx 100cm high and the lower part will be sandfilled, because i do not need al the volume for the seas
As i have learned, baffle step compensation can be avoided by a wide baffle design. Is there a way to calculate the width of the baffle to avoid a baffle step compensation There will be no cross overs in te speaker, it will be active and driven by gainclone amps. The (passive) crossover is put in the pre amp and uses B1 buffers. |
#2 |
You can use EDGE to simulate your baffle:
Home of the Edge You will find that the baffle-step cannot be avoided, only pushed downwards in frequency as the baffle size is increased.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles |
#3 |
a good way to deal with baffle step is to add a .5 way driver, crossed over 1st order at the baffle step frequency.
Saying that, I built two sets of 2.5 way speakers using the same drivers, one set was in 30cm wide cylinders, the other 50Cm wide thin box. The wide boxes sound MUCH more solid in the low mids - drums sound fantastic. Go wide...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
| Fr125S: wide or narrow baffle | bro | Full Range | 28 | 1st November 2006 09:15 PM |
| Possible wide baffle project | Scottmoose | Full Range | 6 | 25th September 2005 01:16 PM |
| If a baffle is 2 meters wide, what is the frequency where the sound | 454Casull | Multi-Way | 18 | 2nd August 2004 08:18 PM |
| narrow vs wide baffle and port location....? | AudioGeek | Multi-Way | 3 | 9th May 2004 09:19 PM |
| Page generated in 0.10520 seconds (53.91% PHP - 46.09% MySQL) with 10 queries |
