hello, what Monacor drivers would you advise for :
- a 4th-order Bandpass (35 Hz to 120 Hz) (5" to 8" diameter) - a Bass-Reflex box (120 Hz to 6 kHz) (3" to 5" diameter) Thanks |
#2 |
Hi Steph. The MONACOR SPH 130 seems to be the best mid. Of course you and others, will have to pay me a lot of cash for this information.
#3 |
I would also test/simulate the Monacor SPH-200KE (against the Monacor SPH-176) for the bass 4th-order Bandpass. Regards
#4 |
Here is Monacor SPH-200KE + SPH-130 combination simulated with LTspiceIV, including the active filters. See attached .zip.
#5 |
Here is Monacor SPH-265 + SPH-130 combination simulated with LTspiceIV, including the active filters. See attached .zip.
#6 |
It's an active xover right? You have the drivers in phase (0º phase/same phase) I suspect. Now if there is a difference like a relative offset between the woofer and the tweeter in which the AC of the woofer is located behind that of the tweeter, how do you deal with the phase alignments.
Note: In the case, a more complex, 4th-order Bandpass phase (does it matter or only for higher frequencies in this case for the tweeter). (1. Time aligned, Phase coherent, Phase aligned, Transient accurate, What's up with that? - Kreskovs) (2. The Evolution of JBL’s Large Format Monitor Loudspeaker - JBL) Last edited by Inductor; 24th May 2010 at 04:04 AM. Reason: JBL.tn_v3n01 |
#7 | ||
Then you realize what kind of electronic monster you are developing, and you may want doing the exact same in digital domain using minDSP or SynthMaker. Regarding miniDSP we need to wait the release of a "free world IIRs + delays" plugin. "Free world IIRs" because as you may have noticed, the "bare hands" crossover filters we are designing here have nothing to do with Butterworth, Bessel and Linkwitz. "Delays" because a delay line is needed when dealing with the tweeter crossover. And I doubt miniDSP will ever be able to execute an intelligent high-pass filter, with a variable corner frequency, for limiting the Monacor SPH-130 excursion in function of the deep bass content. Regarding SynthMaker, we need to wait the release of a Windows 7 Sound System -> VST bridge. Want to do a practical workshop during this summer ? Last edited by steph_tsf; 24th May 2010 at 12:22 PM. |
#8 |
What's that, where?
I'm not very much into active multiple systems, (but) more on passive components. |
#9 |
Anywhere in Cascais. 33% of the time would be me and my wife at the beach, 33% eating and sleeping in a hotel, and 33% you and me designing, assembling and measuring some elaborate audio system. Need to find a decent hotel at a decent price in Cascais. Topics : measuring T/S drivers parameters using AudioTester3 (added mass method), simulating free air, closed box, bass reflex and 4th order bandpass speakers enclosures with LTspiceIV, simulating passive filters and multiway speakers enclosures with LTspiceIV, simulating active crossovers and multiway speakers enclosures with LTspiceIV. Aso with LTspiceIV : positive resistance drive, negative resistance drive, motional voltage extraction and feedback, acceleration piezo disc sensor and feedback.
#10 |
Here is Monacor SPH-250KE + SPH-130 combination simulated with LTspiceIV, including the active filters. See attached .zip.
| Your advice on some new (outdated) drivers | retroman | Multi-Way | 5 | 23rd May 2009 09:20 AM |
| Need Advice for Choosing Fostex Drivers | ezkcdude | Full Range | 5 | 12th November 2007 01:01 PM |
| Drivers for sale - Scan Speak, Visaton, Vifa, Max Fidelity, Monacor, Aurum Cantus... | atalio | Swap Meet | 0 | 14th July 2007 11:58 PM |
| Drivers for sale - Peerless, Scan Speak, Seas, Dayton, Visaton, Monacor... | atalio | Vendor's Bazaar | 2 | 10th March 2007 01:55 AM |
| MCM drivers--need advice | Switch | Multi-Way | 2 | 25th November 2006 07:01 AM |
| Page generated in 0.15903 seconds (78.22% PHP - 21.78% MySQL) with 11 queries |
