Hello
After some experiments building speakers (2-way an 3-way) decided to make Horn - 3 way and the best i see i Klipschorn but unfortunatly i cant find any diy projects with modern (so i can buy them) drivers so maybe some people here can help me? |
#2 |
Try the Klipsch forum and do a search on the Klipsch Jubilee. There are DIY plans available (although their accuracy is questionable). The background and performance measures are detailed in an JAES article by Delgado & Klipsch.
In a nutshell (compared to the original Klipschorn) 1) the bandwidth is extended and can allow for a two-way configuration, 2) distortion is reduced, 3) the build is easier since the angles and bevels are only in a single dimension. Good Luck |
#3 | |
I've owned and modified a set of Khorns. You can do better.
Erik's Horn System |
#4 |
I cook booked a set of Khorns 40 years ago and I have to say modern designs are a better way to go.
Two ways like Geddes's or Volvotretter's or Synergy type horns like Danley's will give you better sound than Khorns. I still have the Khorns modified and I like them, but the modern designs sound better. edit: i haven't heard Volvotretter's but i suspect they'll sound better than the KHorns. Designs like Geddes's and Danley's can give you greater controlled directivity which helps fit them to your room's characteristics and, of course, you are not confined to putting them in a corner. 2 ways with distributed subs is the best way to go, I think. Last edited by FrankWW; 24th May 2010 at 06:46 AM. |
#5 |
Khorns where some of the finest speakers available when they first came out. They are still good, but you can do so much better and for waaaay less.
If you are set on the khorn, then go for it. But, I've had one pair of origanals and one pair of the Speakerlab Ks. And I'd never go back in that direction. |
#6 |
Here is another option. You get a corner horn, plus the controlled directivity that others have mentioned. Take a look at the corner horn from Pi Speakers. These have got very high reviews, and use current drivers that you can buy today. It comes in a kit also. Look at the 7pi kit.
Pi Speakers - unmatched quality and state-of-the-art performance tom |
| diy klipschorn plans? | SIDEWALKSISSY | Multi-Way | 2 | 6th March 2010 12:54 AM |
| A pair of Klipschorn Bass bins + | limono | Swap Meet | 4 | 23rd October 2009 10:10 PM |
| Klipschorn kit speakers for sale | squire68 | Swap Meet | 0 | 16th September 2006 06:38 AM |
| Klipschorn corner horn speaker plans | betection | Multi-Way | 3 | 29th November 2003 07:00 PM |
| Klipschorn chat rooms web sites etc. | Fred Petersen | Multi-Way | 2 | 20th January 2003 08:04 AM |
| Page generated in 0.11545 seconds (81.10% PHP - 18.90% MySQL) with 10 queries |
