I found a pair of Realistic MC-1500's in my Dad's garage this past weekend, and the cabinet looks to be in great shape but the drivers are not. The tweeters are completely destroyed, woofers have a bit of life left but not alot.
Want to bring these guys back to life with some new drivers, but can't find hardly any info on the original speakers! Google searches have turned up very little aside from a few pictures and a reference to the ad in the 1977 Radio Shack catalog (page 21). Anybody know anything about these, or the best way to get started identifying replacement drivers? I checked out Parts Express and their calculater gave me a couple suggestions but I'm not familiar with any of the brands on that site. |
#2 |
The first thing to do is measure the internal dimensions of the cabs, and if they're ported, the dimensions of the port.
Then someone may be able to recommend a suitable driver
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#3 |
You can look for similar speaker in size.
#4 |
Cheap at less than half.
You can get a closer match on the tweeter if U take it apart and measure the hole and flange. Better still post a bunch of pics of drivers and crossover bits. Parts-Express.com:JAMO 20316 8" Paper Cone Woofer | JAMO 20316 8" Paper Cone driver Woofer speaker midrange mid Parts-Express.com:Goldwood GT-25 4" Cone Tweeter | tweeter gt-25 4"cone tweeter cone tweeter goldwood Woofer response will peak 1.5 dB at 100Hz & F-3 is about 60Hz it's typical for these small closed boxes to get the illusion of low bass. U can do better to add a port and shop for better woofer
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust Last edited by infinia; 21st May 2010 at 04:29 AM. |
#5 |
Thanks for those replies. I guess I didn't really phrase a proper question, what I am looking for is either:
-more information on the drivers in that speaker, if it exists -or information about what driver specs to look for to find a good match FWIW Parts Express recommended these 3 woofers: Goldwood GW-408D 8" Poly DVC Woofer Goldwood GW-208/8 8" OEM Woofer 8 Ohm Dynavox LW8004PMR 8" Woofer The outside measurements of the cabinet are 23.63/13.758.5 inches. Seems to be made out of half inch boards, giving inside dimensions of 23.13/13.25/8 inches for a volume of approx 1.43 cubic feet. Not sure how to calculate the volume of the bracing and hardware inside the cabinet. You mentioned adding a port, Infinia. How would I go about determining placement and size of port required? Is the port size dependent on woofer choice or cabinet size? |
#6 |
Let's say we use one of this woofers. Then we simulate it for a box like yours (volume), and check for final xover with tweeter.
#7 | |
the woofers 3 specs ( Qts, Fs, and Vas) If you want to keep it original, stick to closed box alignment So for closed box your looking for Drivers designed as acoustic suspension Qts>0.4 to 1 and the lowest Fs you can find. http://www.diysubwoofers.org/sld/
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust Last edited by infinia; 22nd May 2010 at 03:22 AM. |
#8 |
Great information thanks guys.
| Help with replacement sub driver | Hugh M | Subwoofers | 1 | 11th March 2008 01:19 PM |
| Replacement Driver | jdlech | Multi-Way | 9 | 19th February 2008 10:54 AM |
| Driver no longer available, need replacement | Slanski62 | Multi-Way | 1 | 15th March 2007 01:05 PM |
| Replacement driver | Kittle | Multi-Way | 1 | 7th March 2006 05:51 PM |
| Driver replacement. | prash | Multi-Way | 1 | 14th March 2002 03:37 AM |
| Page generated in 0.11178 seconds (64.50% PHP - 35.50% MySQL) with 11 queries |
