Monacor SP-100-8 LTspiceIV simulations
Old 19th March 2014, 01:46 PM   #11
steph_tsf is offline steph_tsf  Belgium
steph_tsf's Avatar
7. Bandpass 6th-Order Series
You need the above .zip for the subcircuits.
File Type: png 7. Bandpass 6th-Order Series (results).png (19.3 KB, 84 views)
File Type: zip 6th-Order Bandpass Series.zip (410 Bytes, 8 views)
Old 19th March 2014, 01:48 PM   #12
steph_tsf's Avatar
8. Bandpass 6th-Order Parallel
File Type: png 8. Bandpass 6th-Order Parallel (results).png (19.2 KB, 81 views)
File Type: zip 6th-Order Bandpass Parallel.zip (403 Bytes, 7 views)
Old 19th March 2014, 02:17 PM   #13
steph_tsf's Avatar
9. Closed Box - two drivers
File Type: png 9. Closed Box - two drivers (results).png (27.0 KB, 16 views)
File Type: zip Closed Box - two drivers.zip (373 Bytes, 12 views)
Old 20th March 2014, 06:46 AM   #14
steph_tsf's Avatar
The .png file in post #11 was incorrect
Pretty interesting result. A single vent delivers about three octaves of deep bass. Less complicated than the 3-chamber 8th-Order Bandpass.
File Type: png 7. Bandpass 6th-Order Series (results).png (19.3 KB, 10 views)
Old 20th March 2014, 10:23 AM   #15
steph_tsf's Avatar
Let's see what's happening with bandpass designs, when optimizing the group delay.
Such group delay optimization will enable delay compensated subtractive crossovers.
Let's compare the four bandpass designs :
- 4th-Order
- 6th-Order Parallel
- 6th-Order Series
- 8th-Order.
Old 20th March 2014, 10:31 AM   #16
steph_tsf's Avatar
Corresponding bandpass schematics here.
Old 20th March 2014, 10:33 AM   #17
steph_tsf's Avatar
corresponding LTspiceIV .asc files here
Old 20th March 2014, 02:22 PM   #18
steph_tsf's Avatar
The two attached .zip contain all the needed files.
Old 22nd March 2014, 06:04 PM   #19
steph_tsf's Avatar
Bandpass 6th-Order Series & Closed Box (analog design sheet)
Old 22nd March 2014, 06:32 PM   #20
steph_tsf's Avatar
Bandpass 6th-Order Series & Closed Box (digital design sheet)
Monacor SP-100-8 LTspiceIV simulationsHide this!Advertise here!
A fistful of Monacor SP-200X Mikael Abdellah Full Range 20 17th August 2015 06:36 PM
which enclosure for monacor SP-80x Spassgeneral Full Range 7 14th April 2013 09:12 PM
Monacor SP-80X, any experience? Indigestible Full Range 0 31st July 2009 03:05 PM
