Old 19th May 2010, 01:39 PM   #1
activexp's Avatar
Send a message via ICQ to activexp Send a message via AIM to activexp Send a message via MSN to activexp Send a message via Yahoo to activexp
Default Quick, Easy and Cheap (but not nasty) 3-way
Hi all,
For those on a limited budget but still want the satisfaction of DIY speaker building, I've knocked together a quick and cheap 3-way using 12" bass 'bins' and mid/tweeter satellites. The woofers are 4 ohm GDN300 (available from IPL Acoustics) with 95dB SPL in 59L enclosures. For the satellites I used the Skytronic silk dome tweeter and 130mm midrange as both match the woofer's SPL. They are cheap and readily available from Premia-Electronics on eBay. The XO is 1st order at 1000/5000Hz.
The approximate total cost (excluding shipping) of the drivers and XO components to make a pair is £70. For that sort of money the results are surprisingly good and the high efficiency means that even low power amps will have no trouble driving them.
I've done a write-up on my site here:
Quick, cheap (but not nasty) 3-way (stevesstuffproject)
Steve
Quick & Easy request for help - Denon POA-2400 bluesmoke Solid State 13 28th October 2007 09:25 AM
Quick, Cheap & Easy ESL ideas thread bigwill Planars & Exotics 9 3rd March 2007 08:56 AM
Show it again, because easy, cheap and good! destroyer X Solid State 3 4th June 2004 07:51 PM
first easy cheap ect... theChris Parts 5 31st January 2003 07:00 AM
Any PCB - easy and cheap Koy Solid State 8 17th July 2001 02:45 PM
Page generated in 0.13838 seconds (34.17% PHP - 65.83% MySQL) with 10 queries
