Hello,
I have several pairs of the Klipsch 8" woofers sold at Apex Jr. I obtained them from a friend for a song. I have yet to really plan a project with these and was wondering what might happen if the small bucking magnet was removed from the motor unit. What changes in the T/S parameters should I suspect? A lower Qts? Increased SPL? Is there a known benefit to doing this? I was planning on getting the Woofer Tester from PE for some future projects and I would of course measure them after the modification. I am just wondering though if it is worth the effort. I realize it depends on what I want the end result to be....I really don't know at this point because I haven't really thought much about what I might do with them. I really want to know for future flexibility. Thanks for the input! Jeff |
#2 |
In the few comparisons I've seen (can't remember where exactly), the bucking mag usually adds a bit of flux across the gap, so removing it might raise Qes.
#3 |
Custom Title
It'll usually:
Lower Vas Raise Qes (and accordingly Qts) Lower nominal efficiency Possibly slightly alter the spectral tilt, depending on driver.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
| Adding a bucking magnet, what effects does it have | pjpoes | Multi-Way | 2 | 9th November 2008 05:49 PM |
| removing enamel from magnet wire | Zero Cool | Everything Else | 16 | 14th October 2008 08:57 AM |
| Need to shield my Seas 27TBFC/G - should I use a bucking magnet? | owdi | Multi-Way | 4 | 19th August 2006 05:50 PM |
| bucking magnet ? | woody | Multi-Way | 2 | 14th October 2002 03:51 AM |
| Bucking magnet question | woody | Everything Else | 1 | 1st June 2002 07:55 AM |
| Page generated in 0.06340 seconds (69.22% PHP - 30.78% MySQL) with 10 queries |
