#2 |
Ideally, the SS dome should not be XO'd above 2 kHz, because the off-axis response changes a lot above 2 kHz. I seriously doubt you could XO that Dayton tweeter at 2 kHz, right at its resonance. My advice: look for a better suited (cone) midrange.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles |
#3 |
The SS dome will actually be horn loaded so the off-axis response will be a bit different tho, but noted
#4 |
I measured the Fs of one of my ND20FA6 at 1.85khz / 9.61 ohms; X-over LR4 at 2.3khz (5.6µF + 0.35mH + Lpad) worked well mated to a 2" Peerless FR2; I would go somewhere similar with your SS dome, maybe a bit lower i.e. 2.1khz... edit: I guess that using the mid without low-pass could work but will certainly be tricky without using at least a tiny series coil.
crazyhub Last edited by crazyhub; 18th May 2010 at 10:02 PM. |
#5 |
Considering that the 3" dome is flat to 7 kHz on-axis, I dont think its a good idea to run it without XO. You are bound to get very bad directivity, even with a waveguide.
#6 | |
| XO help on cheap PA drivers | AdamThorne | Multi-Way | 25 | 3rd February 2011 01:09 AM |
| Digital XO vs Op-amp XO, which would be best to use in active speakers? | MikeHunt79 | Analog Line Level | 11 | 16th November 2009 05:06 PM |
| How to measure drivers for xo design at low Fc? | tcpip | Multi-Way | 21 | 9th July 2006 04:21 PM |
| Ariel Drivers & XO for Sale! | sianturi | Swap Meet | 4 | 4th September 2004 06:59 AM |
| moving drivers closer together will it effect xo | busterno1 | Multi-Way | 1 | 30th March 2004 09:58 AM |
| Page generated in 0.08773 seconds (72.77% PHP - 27.23% MySQL) with 10 queries |
