![]() ![]() What is that "Fuse" looking thing, is that a resistor (Not use to seeing those). Also what is the 8.2K 100V, I would assume that means 8.2 uF. These are not to important because I will be building a new XO. here is the original on axis measurement. ![]() I thought maybe it was the measurements or something but I tried both speakers and moved them to several locations in the room to make sure. I removed the driver and mounted it on a baffle to build a quick XO on my DCX. Here is the FR plot of my test active XO. ![]() The dip and the peak in the THD are gone now. next step is to get my FR export and impedance exports into Speaker Workshop and sim some crossovers. Just a fun side project from my main waveguide build. The V8s will be my surrounds and I intend on buying 4 more from ebay once I get this done. |
#2 |
I would guess that the fuse looking thing is a light bulb used to protect the speakers from overloading.
#3 |
Thinking it was a light bulb was too easy to consider but looking at the board there is the world "lamp" on it. Cool concept, thanks.
#4 |
I two have pair of v8 with pair of ts8 woofer and it sound pretty good. I am using the xover of the saturn 8. I was wondering if you can send me a copy of your xover you are using on the v8's.
regards' fredc. My emai is infiniti52@aol.com. |
#5 |
Watch out to make sure that ~1.5kHz dip still exists off-axis. It might not, in which case your active XO is putting way too much midrange energy into the room.
Duals should never be listened to directly on-axis, anyway. I prefer 30 to 45 deg off axis. (Even for the center, which is why my front speakers have the center of their 12" Duals ~55" off the ground.) |
#6 |
I use my v8 dual concentric in a 3/4" mdf 9w x 13 1/2d x 23h cabinet (30 ltr internal dimentions) based on the golden ratio and the internal dimensions were suggested by Tannoy. here is the best in my opinion I have tried the saturn 8,v8 and numerous other xover's and it was ok. However I have tannoy 15" 3811/3836 dual concentrics (160 ltr cabinet internal dimensions) i useD multiple xovers as well DMT 15, DMT MKii, GLENAIR, ETC. To my surprise I found an original copy of actual the cpa 15 xover and low and behold my 15's sound terrific. so yesterday I decided I was not satified with the sound of my V8 DC. I opened them up and built an xover with the spare parts I had and matched the cpa 15 xover and to mysurprised they just sound just as good as the 15's and if I did not know better i would sell my 15' and just build two more pairs of the v8's with the cpa 15 xover.
fredc. |
#7 | |
Could you post the schematic for that crossover which you used. I have the dual concentric driver from the system 800's and have wanted to rebuild the networks.
DonM Quote:
#8 |
Here it is: HF
+ _____6.8uf_____2R2_______+ ' .71mh . 5R6 ' - ________________________- LF +________1.5mh___________+ ' ' 20uf ' ' -_________________'________- Last edited by infiniti52; 24th September 2010 at 05:51 PM. |
#9 |
' .71mh . 5R6 ' - ________________________- LF +________1.5mh___________+ ' ' 20uf ' ' -_________________'________- |
#10 |
| Help with Tannoy Eyris crossover mod | iggy111 | Multi-Way | 1 | 23rd November 2009 01:33 PM |
| Tannoy 611 Crossover Conundrum | Sonusthree | Multi-Way | 17 | 28th October 2009 12:43 PM |
| Tannoy FSM Crossover | FMJ | Multi-Way | 0 | 14th December 2007 11:29 AM |
| Tannoy V8/i8 Tuning | inrank | Multi-Way | 4 | 18th September 2007 06:19 PM |
| Tannoy M2 Crossover | BlackWidowAudio | Multi-Way | 0 | 1st February 2002 10:39 AM |
| Page generated in 0.12453 seconds (83.13% PHP - 16.87% MySQL) with 10 queries |
