Which crossover is better? - Page 2 - diyAudio
Old 16th May 2010, 06:28 PM   #11
chris661's Avatar
Good that you're using the software
It must be said, that it's an incredibly flat simmed response. My speakers are nowhere near that... Still, it's sound is a different matter.
I'd agree that the first crossover is better, but for other reasons...
First thing I noticed - the woofer is contributing less further up, meaning there's a lower chance you'll hear the inevitable break-up from the aluminium cone.
The response also looks a little smoother over the cross-over region.
The phase on the first one has a similar curve for both woofer and tweeter, so you won't have any problems with cancellation.
Hope it all goes well
Chris
"If you underspecify some resistors they can add extra phlogiston to the music mix. This gives a much more dramatic effect than refulgence, however superb it may be. Phlogiston can move a listener in a way that ordinary music cannot." - DF96
Old 16th May 2010, 06:44 PM   #12
Inductor's Avatar
Let's see if he can live with that... (nasty and it's still there.)
mondogenerator, did you give the final dimensions, on the software, for the speakers, location of port, and the front baffle dimensions and drivers positions?
Old 16th May 2010, 08:33 PM   #13
mondogenerator's Avatar
It must be said, that it's an incredibly flat simmed response. My speakers are nowhere near that... Still, it's sound is a different matter.....
It is impressively flat, only downside is that the smoothing is 12th octave (i think), and also that i offset the tweeter to reduce the baffle ripple above 5k. However i neglected to measure, and realised my offset is impractical...
When reset to centre position the response is still within +/- 2db though, so i may use a smaller offset, and live with the small ripple. After all im planning to use felt on the baffle around the tweeter to 'blur' the baffle edges a little, and i think this will help with the ripple also.
Soundwise, I am impressed with the test box i have been using for several months, and the crossover that is shown here. it sounds balanced and no unwanted emphases. If i were to pick fault with any of it, i would say that i could perhaps do with 1 MAYBE 2dB less BSC, but I think its to be expected since i have the boxes about 3" from the rear wall, and i really should change that!
....The response also looks a little smoother over the cross-over region.
Chris
Thats exactly my take on the phase response, since the tweeter is not reverse phased it surprises me a little since im used to butterworth curves and the hump or dip thats produced, depending on driver phasing
lol yes the breakup never goes away, however, with the notch i added to the crossover, combined with the LP rolloff, it is attenuated some 25-30dB depending on where you take the measure, so im fairly happy it wont mar the result until i get to 100dBs. And to be fair i doubt i will since the design is only about 84dB/W and i have a 30W amp..
Yes. I used the final driver positions, baffle dimension, bevel on Boxsim to calculate the results. However my german isnt all that great and I am not sure how to input the port position, or indeed IF you can. There are a wealth of options which i still dont understand, even after Chris's Boxsim Tutorial. Which was great, and further than i could get alone. If i could read german fluently, then im sure there are many more things i could include to improve the sim.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 16th May 2010, 08:37 PM   #14
Banned
Foil inductors are superior to wire coil type. I recommend that you bypass any electrolytic capacitors you use with polystyrene, polypropylene or mica caps, unless you want to use non-electrolytics.
Old 16th May 2010, 08:44 PM   #15
Foil inductors are superior IF you think that 'skin effect' is something to worry about in a LP filter, or are after super low DCR. In my application 1mm ferrite cored inductors are perfectly adequate, and the 12 gauge Alphacore foils i have showed no audible difference.
As for caps....well i have not/would not use electrolytics anyway---unless forced by situation...i.e. midrange BP
All caps are polyester film/polypropylene film 1000V rated or above
Old 16th May 2010, 09:28 PM   #16
doug20 is offline doug20  United States
I have never seen actually data that proved this. Could you point out the link for these conclusions?
Old 17th May 2010, 01:00 AM   #17
Inductor's Avatar
Originally Posted by mondogenerator View Post
...I used the final driver positions, baffle dimension, bevel on Boxsim to calculate the results. However my german isnt all that great and I am not sure how to input the port position, or indeed IF you can. There are a wealth of options which i still dont understand, even after Chris's Boxsim Tutorial. Which was great, and further than i could get alone. If i could read german fluently, then im sure there are many more things i could include to improve the sim.
You can use this translation (1, 2) for Port location, front or back, on the dimensions menu. And (3) for tweeter (closed back driver, I think), on the drivers menu. German is not my language.
File Type: gif port-tweeter TRANSLATION for Boxsim.gif (14.3 KB, 27 views)
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 05:21 AM
Crossover help Redgum Multi-Way 5 7th December 2008 06:48 PM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 07:16 PM
Crossover - Three way to Two way... mark.carline Multi-Way 2 5th May 2004 11:42 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 06:48 AM
Copyright 1999-2017 diyAudio
