vented passive radiator sub
Old 19th June 2003, 10:41 AM   #1
raindog is offline raindog  Romania
raindog's Avatar
Send a message via Yahoo to raindog
Question vented passive radiator sub
what are the odds that such a hybrid will work? because i've build one and it works great! does anyone have any theory on this. i'll be back with details
Old 19th June 2003, 12:00 PM   #2
SkinnyBoy is offline SkinnyBoy  Australia
Banned
Send a message via MSN to SkinnyBoy
I made one too.. if it does work (that is the passive radiator moves) then it probably means your port is too small.. lol maybe... lol make it bigger just for the fun of it..
Old 19th June 2003, 12:59 PM   #3
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
Are both the Passive Radiator and the vent facing the outside? Or is the vent internal and feeds into the Passive Radiator somehow?
If you can hae two ports work well in a vented configuration, and two Passive Radiators work well, I suppose we shouldn't be too shocked that a port and a passive radiator work well. However, it is always good to receive confirmation on these matters.
Incidentally, a Passive Radiator theoretically qualifies as a Bass Reflex enclosure, but that term is never used by anyone. Bass Reflex always means vented or ported, in common usage.
One thing. A Passive Radiator, because it has it's own resonance, (in addition to the frequency it causes the box to resonate at), will tend to have a sleeper cutoff slope than a ported box will. Where a ported box will cut off at 24 dB/octave-4th order-a Passive Radiator will cut off at 30 dB/octave-fifth order. From what we have seen here, though, apparently that difference does not seem to cause problems when they are used together.
For newbies, an "order" is a cutoff slope of 6 dB.
Some ported boxes cut off at 18 dB/octave. In which case, their Passive Radiator equivalents will cut off at 24 dB/octave.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 20th June 2003, 03:54 AM   #4
asauer is offline asauer  United States
Send a message via MSN to asauer
Just one question? What's the point. PR is usually used to elminate port noise, and a traditional ported box for ease of use...so why mix the both and then have the bad things from both and none of the good?
vented passive radiator subHide this!Advertise here!
Passive radiator Chris8sirhC Subwoofers 4 5th August 2008 05:49 PM
Passive radiator jamikl Subwoofers 1 3rd June 2006 09:23 AM
Passive Radiator Fazorcat Subwoofers 42 10th May 2006 07:05 PM
passive radiator ??? Ahmad_tbp Multi-Way 20 29th March 2005 07:44 AM
