Old 9th May 2010, 06:57 PM   #1
Default HI-VI D10G woofers.
Hello guys!. Was wondering if someone here tried those?.
I built a 2 way with some D6G's and Morel tweets and i must say
i'm verry happy with the results!.
In the Hi-Vi specs, they seem to point out that it's a bass reflex
suitable driver but, when i enter it's parameters in BassBox6,
it points to "full air suspension"...
I think the D10G is a valuable woofer but, no feedback on it at all.
I have in mind a match with the new Dayton Audio flat, fibre 12inch
passives (ns series" if memory serves me right)
Thanks guys .
Old 11th May 2010, 07:11 PM   #2
Ttt:d
Old 14th May 2010, 12:05 AM   #3
Well, i guess they are junk, nobody here seems to use em...
Old 14th May 2010, 12:56 AM   #4
Loren42 is offline Loren42  United States
Sorry to ignore you.
The Qts is a good and quick way to determine where a particular driver should be installed.
Generally, a low Qts (Qts of .2 to .5) are suitable for a vented enclosure. The woofer you cited has a Qts of .44, which is getting near the upper end of the ideal for a vented enclosure.
In fact, the specification sheet at Parts Express seems to recommend a sealed box of 75 liters.
You could still choose a vented enclosure and the parameters say it can float either way.
Just be sure you entered all the parameters correctly and have the right units.
Also, BassBox Pro is really fun and easy to use, but it really leaves a lot to be desired when it comes to giving you useful information. I would not know if you could trust it for aperiodic design work and I never ventured into such a design.
The real way to do this is to measure the T/S parameters yourself and then take frequency measurements on and off axis. This data should be entered into BassBox Pro so that you can get a better idea of what really happens.
There are also better tools than BssBox Po for this job.
Old 14th May 2010, 01:37 AM   #5
Thanks Loren42!. Bassbox pro does give me a rough response ( seems like a too high
resonance from the passive)...
I still have a lot to "R&D" to do on this...
I want to buid a "D'appolito" passive, w m t m w p if you see what i mean, (twin woofers/
passives), in 3 separated enclosures, stacked together.
Was just wondering if someone had tried those D10G woofers.
Old 14th May 2010, 01:40 AM   #6
No. I have no experience with them, but sounds like an interesting project. You should have your hands full!
Old 15th May 2010, 12:47 AM   #7
Yes indeed. I may use Hi-Vi's F-6 mids and Hiqphone Ow 2 or 3's...
Hi-Vi B3S vs Hi-Vi B3N vs Aura NS3-193 for computer speakers? Vynce Full Range 14 7th July 2010 03:47 AM
HI VI D5.8 woofers...like new transaluminum Swap Meet 0 7th May 2010 06:50 PM
Box volume D10G Hi-Vi. racoon Multi-Way 2 29th June 2009 03:30 PM
FS: 4 New Hi-VI M8n 8" woofers TurboFC3S Swap Meet 1 26th October 2008 12:30 AM
Jordan JX92S + Hi-Vi D10G + passive 1st order crossover? Dumbass Multi-Way 3 26th July 2005 11:57 AM
Page generated in 0.10573 seconds (80.64% PHP - 19.36% MySQL) with 10 queries
