Old 9th May 2010, 02:14 PM   #1
sendler is offline sendler  United States
Default Want to try LeCleac'h horns without spending a fortune?
Want to try LeCleac'h horns without spending a fortune? You can build them out of paper. See the post on the LeCleac'h thread.
Jean Michel on LeCleac'h horns
Scott
Old 9th May 2010, 07:09 PM   #2
acencsu is offline acencsu  United States
What program/spreadsheet did you use to design your template?
Old 9th May 2010, 07:17 PM   #3
Pano is offline Pano  United States
Pano's Avatar
Scott, maybe attach the spreadsheet here if Jean-Michel does not mind.
Take the Speaker Voltage Test!
Old 9th May 2010, 11:35 PM   #4
Default LeCleac'h spread sheet
I used Jean-Michel's fantastic spread sheet that he was kind enough to create. You may ask him about it on the main thread or let me know what parameters you are looking for in a horn and I will post a template.
Scott
Victórios new LeCleac'h horns angeloitacare Multi-Way 85 19th February 2009 01:41 PM
Page generated in 0.11339 seconds (57.11% PHP - 42.89% MySQL) with 11 queries
