Please Check Some Basic Calculations of T/S
Old 7th May 2010, 10:06 AM   #1
CLS is offline CLS  Taiwan
Default Please Check Some Basic Calculations of T/S
Hi there,
I'm trying to find out how much power (or separate V & I) to drive a naked driver to its Xmax.
The main woofer(s) I'm currently using is Eminence SigmaPro18, some of its parameters are:
Re = 6.3 Ohm
BL = 22.1 TM
Cms = 0.24 mm/N
Xmax = 6 mm
Let's assume Xmax happens at very low frequencies. And the driver is naked (poorly loaded), so I can probably throw away air load related parameters etc...
So,
For 6 mm displacement, I'd need 6/0.24 = 25 N of force.
And the motor strength is 22.1, so I'd need 25/22.1 = 1.13 A to have that force.
If at DC, then it's only 1.13 * 6.3 = 7.1 V (or 8 W) to drive it into Xmax.
If at fs, at which point the measured impedance is 190 Ohm, than it's 1.13 * 190 = 214.7 V (or 242.6 W) to drive it into Xmax.
Hmmm... the last one doesn't look right to me.
Besides, an amp has an output voltage swing of 214.7V should be rated @ 5762W into 8 Ohm load !! WTF, something must be wrong here.
In my own experiences, some poor little amps have the ability to drive the woofer into pretty large excursion already. I can't imagine what a fullblown 5~6kW amp can do. Shoot me some cones at a distance?
I also remember Mr. SL mentioned in his web pages that only very little power is needed to drive an ordinary woofer to its Xmax at fs (20~30W IIRC).
So my previous calculation at fs must be wrong. But how? Some other parameters should join in? Is it possible to get the right calculation by just these T/S parameters? Or something else is needed? "Simple" harmonic motions?
Old 7th May 2010, 12:01 PM   #2
Inductor is offline Inductor  Portugal
Inductor's Avatar
I don't know how you can calculate max. W if it varies with frequency. Anyway if you use WinISD you can simulate W for max. cone excursion@frequency wanted.
(1) Green is 200W (Closed box/1200L)
(2) Grey is 300W (Vented/258L/46Hz)
Please Check Some Basic Calculations of T/SHide this!Advertise here!
Looking for a web tutorial on basic calculations RMS Tubes / Valves 3 3rd January 2009 03:26 AM
Need help with calculations please. Wynand Solid State 6 27th June 2006 01:00 PM
Someone please check my calculations j.burtt Multi-Way 5 3rd October 2005 05:17 AM
A basic chipamp in a not so basic case. waltson Chip Amps 19 24th August 2005 07:40 AM
Can somebody please check my bias/heatsink calculations? spence Solid State 10 31st March 2005 08:29 PM
