Old 5th May 2010, 08:07 PM   #1
lduarte1973's Avatar
Question Need help choosing a ribbon tweeter
I Need help choosing the best sounding ribbon tweeter for a 3 way speaker , to replace a 5w tweeter:
NeoCD1.0M SB
NeoCD1.0M SB - Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate - Europe Audio
NeoCD3.0M RB
NeoCD3.0M RB - Fountek ribbon tweeter 4.8cm2 ribbon black alumunum faceplate - Europe Audio
RT1II HiVi research
RT1II - HiVi research Isodynamic tweeter - Europe Audio
RT1.3 HiVi research
RT1.3 - HiVi research Isodynamic Tweeter - Europe Audio
RT1L HiVi research
RT1L - HiVi research Isodynamic tweeter - Europe Audio
Old 5th May 2010, 10:47 PM   #2
pkitt is offline pkitt  United States
I've built speakers using both of the Founteks you listed, but not any of the others. Both Founteks are very good to my ears but you'll have to cross over to the 1.0 at a higher frequency than for the 3.0 just because the two tweeters have different limitations. I prefer the 1.0 but that is likely specific to the speaker system it's in as a whole.
Paul
Old 6th May 2010, 05:28 AM   #3
crossover will be at 4500hz
Old 6th May 2010, 05:31 AM   #4
jerome69's Avatar
NeoCD1.0M SB will be good
Old 6th May 2010, 01:17 PM   #5
My crossover corner from an MDM55 to the NeoCD1.0 was just below 5 kHz.
Paul
Old 6th May 2010, 05:07 PM   #6
frugal-phile(tm)
planet10's Avatar
What are you crossing over to?
One of the issues i had when playing with the Aurun Cantus (a hi-efficiency true ribbon similar to the Fountek) was that the large amount of attenuation required tended to muddy things up. I have found that the OEM RT1 from Creative Sound (made by AC), with its lower efficiency (and greater robustness) is very nice in situations where the higher efficiency units are not needed.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th May 2010, 11:02 PM   #7
crossover is at 800 for midrange and 4500 for tweeter.woofer has 88db , midrange i dont know .
Old 8th May 2010, 01:24 AM   #8
frugal-phile(tm)
planet10's Avatar
With the woofer at 88, mid & tweeter will need to be less than that in the end so the RT1 would be ideal. I have to keep replacing my personal set... "Can i borrow those to try?", then after a bit, "you'll have to get a new pair, i'm not giving these back"
dave
Old 8th May 2010, 09:15 AM   #9
stevieg is offline stevieg  United Kingdom
Monacor RBT-95? not expensive - sound good to me.
steve
if it ain't broke, I ain't fixed it
Old 8th May 2010, 09:32 AM   #10
I'm using Fountek JP3.0 and they are very good IMO.
Due to their simpler (read: lighter) ribbon they actually measure better and are more extended than Founteks more expensive offerings. That said I use them as supertweeters crossed at 10k or so.
Why not a ribbon tweeter instead of a horn tweeter? Curly Woods Full Range 9 15th July 2009 04:09 PM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 08:50 AM
Titanium tweeter vs Ribbon tweeter goldyrathore Multi-Way 14 17th May 2004 07:21 PM
Help with choosing tweeter Mos Fetish Multi-Way 11 18th July 2003 03:01 AM
Choosing a tweeter for something like a proac 2.5 clone Ilianh Multi-Way 2 5th November 2002 02:17 AM
Page generated in 0.09424 seconds (87.68% PHP - 12.32% MySQL) with 11 queries
