In the UK skytec arent renowned for their quality. I have a freind who has used these and say they are awsome. Anyone had expo with them in here?
Skytronic > 8" 250W RMS 500W Peak Kevlar/Rubber HiFi Woofer 8 ohm 16.05 Regards Ric |
#2 |
Crossover-less 2-way
Don't expect very good quality from these drivers. They may also be bad idea for a simple 2-way. Skytronic Drivers There are problems with wrong specs parameters, build quality and notice also the absence of output curves. Don't buy them by mail, see for yourself. For a good design, you have to measure them yourself. |
#3 |
I've been looking at these for some time now.
Although apparently cheap, their spec is pretty good and they don't need a big box to get decent bass. For 8" drivers, they seem to be excellent. I've been debating a speaker like the Infinity Beta model, with 6 of these per box, each with it's own 100W amp, plus midrange and Piezo Tweeters up to 30kHz+ Obviously, electronic crossovers. Sandy |
#4 |
Yes for the price I suspected these were hiding something. Are skytronic just an extension of another woefully crappy brand called Citronic???
I think I'll stick with Beymer and B&C... Quite pricey but top notch! |
#5 |
I use 2x 10" skytronic pp cone "chassis speaker" as my subwoofers in large closed boxes, they work very well with some electronic EQ. Disadvantage of using such cheap speakers was the need for larger enclosures for a given SPL as the xmax isn't great both my subs messure almost identical to my simulations so I'm not noticing any problems with the manufacturing tolerances. In the uk skytronic drivers are used in alot of budget PA gear and car audio installs, cricklewood electronics (London) in particular apeared to have massive stocks of them.
#6 |
Years ago I built a pair of isobaric active speakers with original B200 KEFS died and could not replace. These worked with scan speak tweeters. I took a risk and bough 4 of the skytec 8 inch speakers as an experiment to replace the B200's
Two per box working in parallel. Heavy sand filled boxes. Driven by a 24 db active crossover and 150 watt pch mosfet amplifier. Results were stunning and comparable to units I had paid much more for. Bass is spectacular and deep. Sensitivity is lower than B200 but easy to adjust with active cross over. I now use for my home cinema and enjoy listening to them. I think they are fantastic value for money. |
| WTB: single focal JMLab Audiom 11wx w cone woofer, any condition thanks | elviukai | Swap Meet | 2 | 5th July 2010 07:27 AM |
| WTB: Vifa P17 poly-cone 6.5" woofer 4 OHM (pair) | GordonW | Swap Meet | 0 | 31st July 2008 05:14 PM |
| MCM Aluminum Cone Woofer for TL ? | NepaEric | Multi-Way | 17 | 8th December 2007 02:10 PM |
| Vintage Wharfedale 12" styrofoam-cone woofer | GordonW | Swap Meet | 1 | 25th August 2007 09:38 PM |
| diy cowpie-cone woofer | Groundloops | Planars & Exotics | 1 | 8th May 2007 07:04 AM |
| Page generated in 0.08963 seconds (75.23% PHP - 24.77% MySQL) with 10 queries |
