Old 3rd May 2010, 07:58 PM   #1
Default 15" + Mid + Horn
The bass drivers I will use will be C15-400B. PDF
Searching for a horn, I came across with CP 800TI from Beyma which has low 2nd and 3rd order harmonics for a compression driver. PDF
But it has the SPL value to high (for 1W). A L-pad will help but with some disadvantages.
The horn used in Beymas test is TD590. PDF
The polar response is not so great.
Next step.
As you can see from the graphs at 5W the C15 will have over 100dB at 50Hz.
It will be a problem matching this with a good mid driver.
The possibility of 15" + 2" driver will work only if I find one suitable for the job.
The test enclosure is 110 L, FB 45Hz, 20% Damping (40kg/m3). Full space simulation (anechoic).
Old 3rd May 2010, 08:09 PM   #2
Speakerholic
Cal Weldon's Avatar
Have a look at this page for some 8" and 10" drivers to complement.
http://www.parts-express.com/wizards...AT&srchCat=579
http://www.parts-express.com/wizards...AT&srchCat=580
I don't think you'll have to worry about 100dB 1 watt at 50 Hz. Take a look at the graph they post on your linked page. I see 93 - 94 like your graph on the left shows.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 3rd May 2010, 08:24 PM   #3
The response in the PDF file is in Free Air.
From Leaps graph I find the following:
150 @ 97dB
200 @ 98.5dB
above 200Hz the SPL increases slightly to about 100dB.
This are also in Free Air.
Delta Pro 8 might work. Breakup range starts at rougly 3Khz.
Old 3rd May 2010, 10:18 PM   #4
Speakerholic
Cal Weldon's Avatar
Free air or IB?
Old 4th May 2010, 06:34 AM   #5
Free air.
Old 4th May 2010, 06:46 AM   #6
ScottG is offline ScottG  United States
Originally Posted by Cal Weldon View Post
Free air or IB?
Yeah, I don't believe it either.
perspective is everything
Old 4th May 2010, 06:47 AM   #7
StigErik's Avatar
The graphs cant be correct. Based on the T/S parameters, I find that free air (4pi) sensitivity of the woofer is just 89,65 dB. At 5W that is not more than 96,6 dB.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 4th May 2010, 07:28 AM   #8
Re-running.
I know that graphs are inaccurate and that`s why I will build a test box to assess it.
Later:
Same result. The box was rectangular due to laziness.
P.S.
Attached graphs from LEAP database.
First one is free air, second inf baffle.
Horn Loaded 15-18" led_zeppelin Multi-Way 20 28th February 2012 12:00 AM
need help designing 15" folded horn. duck1 Subwoofers 14 8th May 2008 09:21 PM
P-Audio 15" coax - horn or cone feed best? freddi Multi-Way 8 18th February 2007 09:09 PM
Looking for a ~40-300Hz Horn solution with a 15" Driver Bass-Depth Multi-Way 20 1st April 2006 04:19 PM
Can I multiply an 18" folded horn cab by 0.8 for a 15"? Optical Subwoofers 7 31st October 2004 04:37 AM
Page generated in 0.10549 seconds (80.20% PHP - 19.80% MySQL) with 11 queries
