Occasional lurker here, now registered - please be gentle!
So here I am, trying to figure out how to build the perfect multi-way speaker for a tube amplifier. The basics I know: a linear and preferably not-too-low impedance and a high efficiency. But which other parameters play a role? Voice coil inductance? Overall number of voice coils (and inductors in the crossover?) in the system? Stiffness of the driver's suspensions? Moving masses? And how do these things mesh, which one of them is really important to how well a tube amp works with the speaker? Looking forward to your answers! the Interceptor |
#2 |
Hi Interceptor and welcome to the forum.
Of course you know there isn't any perfect speaker, not for tube or otherwise. I'm not being smart, it's important to keep that in mind. Everything, absolutely everything is going to be a series of trade-offs. That said, here is my general (tho not perfect) guide to what works well with tube amps.
That's my list. I have not found voice coil inductance to be a big deal, as long as it's dealt with in the crossover. As for moving mass and stiffness, the more efficient drivers tend to have low mass for their size and are stiffer than average. I'm sure there will be plenty of other suggestions.
Take the Speaker Voltage Test! |
#3 | ||
frugal-phile(tm)
A reactive impedance changes the loadline to an ellipse. Now, in general, a flat impedance will be of benefit to most amps. Quote:
How efficient you need depends of course on how much power you have. And needs to be tempered by the impedance. A high efficiency speaker with a wild impedance, will most often not be as effective as a less efficient speaker with a benign curve. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Thank you for the salutation and the answers so far. Allow me to to shed some light onto why I am asking, maybe this will spark some more discussion.
My idea is this: a tube amplifier more or less is bound to have a fairly low damping coefficient. Thus, it makes sense to engineer a speaker which is very simple to drive for the amplifier, with "simple" referring to neither resisting incoming currents too much, nor sending too much back by inducing a back electromotive force (BEMF). But how does one achieve that in a speaker? Well, what I am thinking of is to reduce the number of voice coils in the system and to make sure that those which remain have an inductance (Le) as low as possible. Theoretically, this should minimize the complexity of the speaker in the eyes of the amp and thus make them a good team. However, I am not sure which role a factor like the strength of the electric motor (BxL) plays in this. Maybe reducing the Le makes no sense when the BxL is so high that the induced BEMF is higher than with a driver with a lot of voice coil inductance, but a low BxL. Also, I have noticed that most of the speakers which are known to work best with tube amplifiers, like horns with Fostex drivers for example, have one thing in common: they are equipped with drivers with a low moving mass, but also a soft suspension. This path is being left further and further with modern drivers. Those mainly sport higher moving masses and harder suspensions. And it makes sense, too, because amplifier power costs next to nothing nowadays. Nonetheless, my understanding of the matter is that a weaker and "softer" tube amp will have a very hard time propelling such a driver, because the latter will "demand" a certain amount of power and will "lean into the amp" (produce a lot of BEMF) before it starts working properly. On that basis, it seems to me that a driver for a multi-way system which is supposed to work well with a tube amplifier should be made in a way companies made them before wattage became largely available. And I'm not even talking about vintage drivers, just low moving masses, soft suspensions and averagely dimensioned electric motors. Such drivers have become unpopular because they need lots of air and will reach their mechanical limit quite quickly. But keeping tube amps in mind, maybe they were not so bad after all. Anyway, I am not certain how true as well as important my observations really are, thus I am looking for the insight of those who have been looking deeper into this matter. |
| Does speaker Qts matter in door installations? | mda185 | Car Audio | 19 | 29th July 2009 07:59 PM |
| 1st BIB, or diy speaker for that matter | masterxela | Full Range | 5 | 9th April 2008 04:22 PM |
| Tube amps, power and speaker impedance | Klimon | Tubes / Valves | 3 | 11th January 2007 07:32 AM |
| SMPS for diy audio amps and multi-channel diy amps (and their power supplies) | tlparker | Solid State | 18 | 31st August 2006 10:39 AM |
| 2-way speaker narrow midrange dispersion - does it matter? | arjscott | Multi-Way | 6 | 2nd May 2006 03:54 PM |
| Page generated in 0.09814 seconds (78.99% PHP - 21.01% MySQL) with 10 queries |
