Two Silver Flute W14RC25-04 ohm 5-1/2" Wool Cone from Madisound in Parallel crossed over at 3300 .18 mH and 12 uF cap weighted with 5 grams of clay and sprayed with urathane to increase stiffness of the cones
http://www.madisound.com/catalog/PDF/DQ25SC05-04.pdf used from 3.3 Khz to 12khz 6 uF and .4 mH with and additional .05 mH after the speaker to cause the cut off at 12khz and smooth the rise at 10 Khz C audi0 tweeter from 12 khz using a 2 uF 3.9 ohm resistor to load balance the amplifier around 4.5 ohms Pictures and graphs to follow LR2 expected spl is 92db or 93db The design is based on this layout used on the Qyaonic Tad Last edited by mcmahon48; 30th April 2010 at 10:00 PM. |
| audio nirvana super 10 or super 12 | tonytex | Full Range | 11 | 4th September 2011 10:55 PM |
| Nirvana super 8 and cast super 8 how do they compare to 206E? | freddi | Full Range | 4 | 22nd October 2010 02:29 AM |
| FS: SUPER CD PRO KIT with SUPER SHOCKPROOF | bbp | Swap Meet | 5 | 17th April 2009 05:09 AM |
| Sub Development | jwatts | Subwoofers | 21 | 11th June 2006 07:30 PM |
| Interesting development | StevenOH | Everything Else | 2 | 10th October 2005 06:26 PM |
| Page generated in 0.05441 seconds (80.32% PHP - 19.68% MySQL) with 11 queries |
