Old 25th April 2010, 08:18 PM   #1
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default Eminence 3012HO
OK...bear with me folks. I have a DIY MTM tower pair that has finally blown the surrounds. I am now building a low power tube amp (2.2 W) so I need to jump up the sensitivity multiple factors. The existing enclosure is appx 9" wide by 13" deep and 48" high. The current BAD drivers are set-up as an MTM 6 1/2".
As I cannot seem to find a high sensitivity 6.5" pair I am considering flipping the enclosure around & mounting a larger more sensitive driver on the "long" wall.
I found the Eminence Kappalite 3012HO Neo with the following specs.
100.5 Db, Vas 2.86cu ft, Qts .32, Qms 8.39, Qes .33, Fs 51.5 Htz, 51-3500 Htz.
The numbers say I can work with this volume of enclosure (2.28 cu ft. ).
Has anyone had any experience with this driver? Am I really off base with this driver?
__________________________________________________ _______Rick....
Old 26th April 2010, 04:59 PM   #2
Brett's Avatar
3012HO measurements and used the the No Quarters (same guy who did the measurements) and possibly in some of the Econowave variants, but you'll need to search for them yourself.
Old 26th April 2010, 05:04 PM   #3
doug20 is offline doug20  United States
Some more builds with that driver...
Flex Your PCD Mettle: - Techtalk at Parts-Express.com
eminence asifqabil Multi-Way 1 8th December 2008 06:03 PM
Enclosures for Eminence Sigma 18" and/or Eminence Kilomax 15", PA-sub application esaias Subwoofers 8 10th August 2005 05:17 AM
Eminence Lab12 smallangryboy Subwoofers 17 21st March 2005 03:22 AM
Eminence? kvarnis Multi-Way 7 19th July 2004 09:36 PM
where to get eminence drivers welly_59 Multi-Way 15 2nd December 2003 11:19 PM
Page generated in 0.07218 seconds (71.45% PHP - 28.55% MySQL) with 11 queries
